DDP Vs. Formula One
The 1.75's are a custom nozzle, rated at 95hp. Don told me when I got them a while back that they may make 5 or 10 more ponies more than that on a HO motor. I also replied to you PM...
I believe the 1.6's, 4's and 6's have the newer technology.... advanced hole patterns, spray angles, and maybe hole cutting technique, etc. Subtle differences along those lines.
These changes produce better HP, less smoke and lower EGT's, if I correctly remember what Don said.
RJ
RJ
RJ
RJ
If you don't tow heavy, I would go with the 4's and turn the box down if the heat gets to high. Personally I like driving with more of the power being made by the injectors, then with the box. Then down the road, put an S400 under your current turbo, and turn the box up. I made 510hp with a turbo similar to yours, and mach 4's. Real toasty though. I went to the set of twins I have now, with the 4's and made 565hp.
Paul
P.S. Oh yeah.... It tows really well now!
My truck gets better fuel mileage than stock. I barely pulled 16-18mpg, stock. Today I range from 18-21mpg. You tell just by the smoke that comes out of the trail pipe that Don's injectors are atomizing better than the stock. The only downsize to large injectors is that your oil will get dirty faster than stock. Your bumper will turn from a semi-clean, hazy black to a dark black soot. Mine truck will smoke but there has been times its hard to tell the difference from my old BD injectors that I ran before (220rwhp sized vs 90rwhp). The power is way way up. For most trucks I wouldn't run a injector larger than mach 6er's. The larger injectors idle worse and after a hard 1/4mile blast you might stall at the end. My truck will stall when going from idle to in gear(when started and try to run cold). When warmed up this doesn't happen with any other injector I have ran.
Paul
Rpainter
May 11, 2007 05:50 PM
caleb c.
27
Apr 25, 2007 10:34 AM
Marine
24
Oct 6, 2006 09:54 PM
snowmanx
Sep 26, 2006 08:12 PM
