Custom grind fuel plate
Old Feb 3, 2013 | 02:38 PM
richard's Avatar
So I decided to try to grind my own plate from a stock one I had laying around. I took the profile of a TST #10, made it a little less severe. Then adjusted the afc housing, governor arm, and star wheel.
This truck has never run so crisp. I can control the smoke with my foot, and if there was any power loss it was minimal.
And under a hard long pull, i can still generate enough boost to blow a boot off the intercooler. Going to be replacing all of them soon enough.
The point is don't be afraid to try it. You may be pleasantly surprised with the results.
Old Feb 4, 2013 | 12:06 AM
Tate's Avatar
Pull the plate out, you'll be even more impressed.
Old Feb 4, 2013 | 05:00 PM
infidel's Avatar
Get gauges before you do anything.
Stock plate slid all the way forward, no pyro
Old Feb 5, 2013 | 07:16 AM
jughead's Avatar
A-men on the gauges
Old Feb 5, 2013 | 07:43 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
I'm not sure about this...I cut a zero plate for my truck...Works good...But unsure if the zero plate is the same as no plate...
Old Feb 5, 2013 | 09:35 PM
9812vram's Avatar
X2 I wonder the same...
Old Feb 5, 2013 | 11:48 PM
Tate's Avatar
Depends on the plate position and AFC position. Cut a deep 0 plate, and you may hit the rack plug before the plate. If the AFC is to the rear, it may stop the gov arm before it ever contacts the plate.
BigBully
29
Jan 18, 2007 10:10 AM
West Coast
Oct 4, 2005 10:03 PM
kevellis32
Apr 8, 2005 08:14 AM
gunracer1
16
Feb 1, 2005 09:53 AM
cummins42
Jun 2, 2003 06:00 PM
