#10 Fuel plate. Grind my own or Buy it???
Better to save up that money for another more expensive modification..
Rick
Ditto what they said!!! I used a bench grinder to get the general shape of the plate and then used sandpaper (100, 150, and then 220 grit) to get it exact and polished it with a buffing wheel and polishing compound in my drill
. Looks awesome with the face like a mirror and rides super smooth against the govenor arm
Shawn, grinding the plate isn't rocket science. My bet is every 100 plate's tip is different from the next one. Also where the gov arm is adjusted makes the curve of the tip a mute point.
I'm sure it isn't, I do however like to be 100% positive before doing something anytime the outcome can produce mass failure. Thanks for the heads up though, that takes the worry out of it
Shawn
Shawn
Just pull your plate completely. A #10 plate doesnt even make contact with your throttle arm anyway. IMO a fuel plate is a waste of money, when you can just pull it out and make more horse power and adjust the afc as needed.
a plate is not a waste of money, i consider it cheap insurance to prevent damage to the internals of the injection pump.
KuhKuhKyle, if u insist a plate is a waste of money so be it, but with the proof already in stories and damages that have been documented with people running without a plate, its not even worth the risk, and even so, if u want to run plateless, at least adjust the governer arm so that it does not travel under the plate. I have a 100 plate, and u can adjust the plate positioning or the governer arm to hit the plate as needed. Ive done both to my truck.
Plateless, if it was such a good thing, why isnt everyone doing it?
Rick
Well Rick. In all applications I have been around, I've seen plateless trucks completely undamaged. All the #10 plates that have been made, dont touch the arm anyway. I myself have bench tested this plate and a plateless p pump. Both provide the exact same fuel flow of at least 400 cc's of fuel per thousand strokes of the pump, to the 110 cc's per 1000 strokes of the pump. All a fuel stop plate is, is another restriction. If building a ton of horsepower is your goal, why restrict your fuel flow? This is just my opinion. I've never seen any damages to a plateless pump personally. I know of a few pumps where guys have ground their plates, and put it back in to have the bolt get loose and back out to cause damages. Only cases I know of.
