Comp question
Old Nov 28, 2005 | 05:28 PM
eric13's Avatar
Comp question
IF I tapped the wrong wire at the pump will the truck run?The reason I ask is that I have a comp and 275 injectors and I cant get any more than 22 lbs of boost and cant get the egts over 1150 or so no matter how hard I beat on it.Thanks in advance.
Old Nov 28, 2005 | 05:55 PM
dieseldork's Avatar
I Think I Would Try And Tap The Other Wire And See . I Have About The Same Setup As You And I Can Hit 30 Psi And 1400 Extemp. Also What Part Of Ohio Are You From?
Old Nov 28, 2005 | 06:04 PM
blackdiesel's Avatar
Registered
if you tapped the top one, you got the right wire.
Old Nov 28, 2005 | 06:13 PM
eric13's Avatar
I am about 55 miles east of cincinnati right on the river. I am afraid to tap the other wire because i dont want to mess up my pump. Any body ever tap the wrong wire and realized later?
Old Nov 28, 2005 | 06:14 PM
BigBlue's Avatar
You should definately be hitting more than that. It's top wire wire closest to the head. Kind of a pain to get to. How did you go about tapping it?
Old Nov 28, 2005 | 06:30 PM
eric13's Avatar
I took the intake off and the tps(I guess thats what that was) then used the scotchlock that came with it. The insructions show a pic as you already know but it is kind of fuzzy.
Old Nov 28, 2005 | 06:44 PM
BigBlue's Avatar
There's your problem. The scotch locks are notorious for making a bad connection. Solder the wire on there or use a different style connector and that should solve your problem.
Old Nov 28, 2005 | 06:54 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I have just the comp with stock injectors and I can hit 30 psi boost without trying.
I also used a BlueChip Pump Cover instead of the Mickey-Mouse scotch-lok.
Old Nov 29, 2005 | 05:47 PM
dieseldork's Avatar
On My Comp I Used The Posi -lok It Makes A Pretty Good Connection. But It Is Hard To Hind A Place That Will Just Sell One Of Them .
Old Nov 29, 2005 | 06:03 PM
Gotlift01's Avatar
well the reason you are only getting 22psi is because of your wastegate. Put a J-hook or a turnbuckle on that sucker and you will be in the 30psi range no problem.................but it sounds like its not getting a good connection, because you should be seeing a lot higher egts than what you stated!!
~Nick
Old Nov 29, 2005 | 06:16 PM
eric13's Avatar
I have the bullydog J-hook on my wastegate.So I dont think thats it I havent had a chance to mess with it but I am going to unhook the pump wire completley and see if I feel a difference in the truck if I do I know I had the right one if I dont then I had the wrong one or a bad connection.
Old Nov 29, 2005 | 09:25 PM
eric13's Avatar
well i pulled the wire off and I did notice a difference so I must have had the right wire, so I wonder if there is something wrong with my box? I cant figure out why Im not getting any more boost than I am. I am happy that my egt's are not high, but that also is leading me to believe that there is something wrong.I know when I first hooked it up I was getting the code P0236 which is the overboost code I believe. Ater about a mont and a half it is finally gone. Guess I just need to get in touch with Edge.
aybe even get it upgraded to the Drag.
Old Nov 30, 2005 | 09:20 AM
Gotlift01's Avatar
Yeah I would for sure send it back to edge to have it looked at. Because if it was working right, you should be able to hit 1400* EGT and 30 some psi........at least that is what I get with mine!!
~Nick
Old Nov 30, 2005 | 10:10 AM
eric13's Avatar
Thanks everyone for the help and ideas.
taken5875
Apr 4, 2008 12:48 AM
rockjeep73
Mar 25, 2005 03:34 AM
hellotbone
Jul 12, 2003 12:58 AM
hellotbone
18
May 16, 2003 04:40 PM
danlit
Feb 13, 2003 10:53 AM
