Comp and boost question..
Old Dec 15, 2004 | 06:35 PM
I SPEED's Avatar
So I'm running a Comp with the wire tapped, and only getting about 27lbs of boost with a turnbuckle and spring setup. (without the turnbuckle setup she's only good for 21lbs)
It's an auto so I can't run the elbow.
What numbers are some of you others getting with similar setups? For those with higher numbers, how did you achieve them?
Old Dec 15, 2004 | 10:53 PM
ratsun's Avatar
Re: Comp and boost question..
[QUOTE]Originally posted by NOSPIN4ME
[B]So I'm running a Comp with the wire tapped, and only getting about 27lbs of boost with a turnbuckle and spring setup. (without the turnbuckle setup she's only good for 21lbs)
__________________________________________________ _______________________
I'm not sure if the 01 has a different turbo than my 98 but I run the boost elbow with mine and it will go 35+ However with small injectors its still way to hot
taken5875
Apr 4, 2008 12:48 AM
dodgediesel
14
Dec 14, 2006 09:54 AM
rockjeep73
Mar 25, 2005 03:34 AM
BigBlue
Mar 22, 2005 06:16 AM
CTD_Neil
Jan 12, 2005 06:07 PM
