Common rail in a 2nd gen
Old Sep 13, 2005 | 12:22 AM
95ram's Avatar
Has anyone put a common rail in a 2nd gen pickup. Just kind of curious how it was done and what it took.
Old Sep 13, 2005 | 08:24 AM
gunracer1's Avatar
james lucas is putting one in his 2001, it should be a monster.
Old Sep 13, 2005 | 08:27 AM
G-NOTE's Avatar
Question
I have the oppurtunity to get a 03' motor let me know what I can use on mine, maybe the turbo/intake/injectors .... I don't know let me know.....
Old Sep 13, 2005 | 08:48 AM
CTD NUT's Avatar
You won't be able to use much from your 2nd gen engine.....while the short block and cylinder head are quite similar, the 3rd gen uses a completely different intake and fuel system that does not have any common parts with a 2nd gen.
Old Sep 13, 2005 | 11:47 AM
yarddog's Avatar
What would the advantage of swapping to common rail be?
Better mpg, more potential for power, more aftermarket support?
Old Sep 13, 2005 | 11:53 AM
CTD NUT's Avatar
I don't see any advantages other than you wouldn't have to deal with the @!#%*#$! VP44 anymore....on the other hand, as expensive as it is, I would expect you would be much farther ahead $ per hp to swap in a P7100 on the 24v than to bother with the HPCR.
Old Sep 13, 2005 | 01:01 PM
JDGnut's Avatar
A few issue back in the TDR.. there was a 1st gen with the HPCR engine...
Bryan
Old Sep 13, 2005 | 03:50 PM
G-NOTE's Avatar
Talking
I was just curious since I have access to a plethera of cummins motors!!!
Old Sep 14, 2005 | 12:28 AM
95ram's Avatar
HPCR is easier to mod with plug and play and it's quiter. It would be for the wifes pickup. The main reason people swap in the 12V is because its easy IMO.
Old Sep 14, 2005 | 07:36 AM
Dr. Evil's Avatar
IMO< the main reason people would swap in a 12V is because its RELIABLE. Im still not sure why anyone would want to do this. I dont have much confidence in the third gens, JMO.
Flatbed24v
Dec 22, 2008 12:03 AM
estshrrdnck725
Sep 18, 2008 01:24 PM
Marty86
Sep 11, 2007 07:31 PM
FDPOWER
Aug 6, 2007 10:49 AM
getblown5.9
Jan 10, 2006 04:55 PM
