Common rail 2nd gen?
Old Dec 21, 2008 | 10:06 PM
Flatbed24v's Avatar
ok I know you can p pump a vp truck but can you put a cp3 and common rail on a vp truck? Why or why not?
Old Dec 21, 2008 | 11:21 PM
Bjans's Avatar
you would have to swap everything over. Ecm, head, injectors, cp3 rail, etc. The common rail's injectors are fired electronically not off pressure like the vp's. With a common rail the cp3 pressurized the fuel at high pressure to the injectors then when its ready to inject the electric solenoid opens allowing the fuel in the cylinder, where as with a vp setup it pressurizes fuel as needed to the injector and the pressure actually opens the injector and injects the fuel. probly not the best explanation but ya.
Old Dec 21, 2008 | 11:37 PM
Canadian24v's Avatar
the blocks changed in when CR came out. the front gear housing won't bolt on to a storm block.
Old Dec 21, 2008 | 11:52 PM
Flatbed24v's Avatar
what about using the cp3 and find a way to adjust it down to the right injector pressure. I figure if it could been done then you could get the flow of fuel needed for high hp and adjustablity of electrically controled injection pump.
Old Dec 22, 2008 | 12:03 AM
Bjans's Avatar
A cp3 only has one output and the vp has one for each injector (6). it just wont work with anything "vp" related (injectors, electronics)
estshrrdnck725
Sep 18, 2008 01:24 PM
Marty86
Sep 11, 2007 07:31 PM
FDPOWER
Aug 6, 2007 10:49 AM
getblown5.9
Jan 10, 2006 04:55 PM
95ram
Sep 14, 2005 07:36 AM
