Collapsed AFE
Old Sep 12, 2005 | 11:43 AM
HOHN's Avatar
Originally Posted by duke1n
Am I hearing that it is not possible that it has collapsed due to intake vacuum? Thx
Anything's possible. But I'd venture to say that you would explode your turbo before you'd collapse a filter from suction. It would take not just restriction, but BLOCKAGE of the filter to cause a collapse. Like Saran Wrap over the whole thing. But it would have to be over the whole filter in order to happen.
If you had that kind of blockage, the vacuum being drawn in the intake tract would drastically increase turbine shaft speed, and I'd think that you'd grenade a charger before collapsing a filter.
Do guys running twins that have an AFE setup have collapsing issues? That's more air than you have by a decent amount, isn't it?
From the provided picture, the damage falls along a crease for the most part. That points to PHYSICAL damage in my book.
jmo
Old Sep 12, 2005 | 12:49 PM
TORQUE's Avatar
Looks like physical damage to me. Had any Ford or Chevy guys drooling over your unit, and maybe sabotaging it.
Old Sep 12, 2005 | 12:54 PM
duke1n's Avatar
Them unit droolers love me on the Fode and Chebie sites lol
Ok ok so everyone thinks I smashed the cat in the hood. I still don't think so and if I replace it and a week later it looks the same way(no cats involved) then I'm going to lose a lot of faith in you internet experts lol.
Old Sep 12, 2005 | 01:12 PM
rharveysr's Avatar
I have seen one of these filters look like this on a truck with a PDR HX35/14 pulling the air. I have no idea why they are doing it but some are..
Rick
Old Sep 12, 2005 | 04:50 PM
G-NOTE's Avatar
Lightbulb
Did someone clean it for you, some people (like jiffy lube tech's) like to bang these filters on the ground to dislodge any loose dirt particles. This would cause it to collapse like that I know first hand from my filter on my cobra!!!
Old Sep 12, 2005 | 05:18 PM
pmtg's Avatar
is the filter's heat shield/mount secure? maybe the filter is bouncing around because the mount isnt secure?
maybe a motor mount not tight enough allowing motor to twist side to side and jamming the filter against the firewall/fender area?
any evidence filter has been hitting firewall on the black sound deadener stuff?
let the brainstorming continue...
Old Sep 12, 2005 | 05:44 PM
GSP's Avatar
GSP
Those filters get smashed pretty easy . I had one on a dirt bike that is bent to hell.
Maybe a cat got up in there.
Old Sep 13, 2005 | 12:42 AM
CookieMonster's Avatar
I've had that happen to me twice so far, first time was from the guy at the oil change place using it as an elbow rest while fighting with the oil filter and the other time was when I let the "Sock" or AFE pre-filter screen get plugged up with dust, the filter actually got sucked inwards and crushed even though the filter itself was relatively clean. I was totally amazed at how much that pre-filter actually does and I swear by them now!!!!!
Old Sep 13, 2005 | 08:27 AM
SjLingenfelter's Avatar
My AFE does that too..and Im the only one that has been workin on it since this filter was put in...I only spool 38psi. Will AFE replace them if we send it back to them?
Old Sep 13, 2005 | 09:11 AM
HOHN's Avatar
I'd expect them to. It's totally unacceptable for filters to collapse so easily. Maybe AFE is cost cutting?
sinawalli
Mar 5, 2011 08:43 PM
toddbweaver
Dec 1, 2008 04:00 PM
surfram
Jul 17, 2006 02:06 PM
diesel_work
Oct 8, 2005 12:25 PM
sawboywv1
Jul 15, 2004 10:31 AM
