code help
Old Jul 10, 2006 | 09:48 PM
Justin26's Avatar
code help
My buddy just called and said he put the edge comp on his truck and it thru a couple of codes after the install. 0237 and 0122 He has got a 2002 dually 6 speed. Can anybody help with the codes or tell me how to get the list where it shows them. Also can u stack the edge juice with the edge ez?
Old Jul 10, 2006 | 10:10 PM
natlchamp2k4's Avatar
P0122 TPS Throttle Position Sensor? APPS Acceleration Pedal Position Sensor Voltage too low
P0237 Turbocharger boost sensor A curcuit low Manifold Absolute Pressure (MAP) sensor voltage low
Haynes repair manual
No you cannot stack the EZ and the Juice, they both use the data port and are both timing and fueling.
Jamie
Old Jul 10, 2006 | 10:14 PM
Justin26's Avatar
Thanks for the info.
Justin
coope3
Feb 21, 2009 04:49 PM
kenny1987
Jan 24, 2008 01:19 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
