CD Player Installation Questions
Old Oct 10, 2006 | 04:24 PM
Hillbilly_Deluxe's Avatar
I recentley tried to install a Kenwood deck in my 2001.5, I'm not sure if it has the Infinity sound system although it does have the A Pillar tweeters. I hooked everything up it had power, but no sound, any suggestions?
Thanks
Jared
Old Oct 10, 2006 | 05:44 PM
JKM's Avatar
JKM
https://www.dieseltruckresource.com/...d.php?t=117594
Old Oct 10, 2006 | 05:51 PM
didn't answer any questions, the only other wire that is there is the ground.
Old Oct 10, 2006 | 06:14 PM
JKM's Avatar
JKM
It is incorporated into one of the plugs that plugged into your factory deck.
Old Oct 11, 2006 | 12:42 AM
MADMATT's Avatar
its to do with the equalizer i think
Old Oct 11, 2006 | 12:51 AM
stock03's Avatar
stereo adapter plug
Did you buy a stereo adapter plug? It plugs from the rear of a new stereo and into the existing plug of the vehicle. It makes stereo installs easier. If the plug and new stereo are in working order, it should work.
Old Oct 11, 2006 | 06:13 AM
Yeah, I have it all wired up it lights up and everything but there's no sound.
Old Oct 12, 2006 | 07:21 AM
juicedbusa02's Avatar
hey if you havent got it yet.... i work at a stereo shop and we see this pretty regularly. Like one of the guys above said.. On the black connector that plugs into the factory side there should be a blue wire. Coming out of the back of the radio there should be a blue or blue with white stripe wire. If it has blue/white connect this one this is the amp turn on wire and everything should work correctly. Make sure you have good ground too. Any questions feel free to ask... hope i could help
Chris
Chris_O
Sep 19, 2003 07:02 AM
rattle_rattle
16
Aug 22, 2003 12:38 PM
kstrongsyj
May 14, 2003 10:39 AM
