Can't do turnbuckle, what else?
Old Mar 27, 2006 | 07:55 PM
hotdram's Avatar
'02 HO (6 speed/HX-35W). With the Smarty I would like more boost. How can I do this, I can't do the turnbuckle trick the auto guys can.
Also, will the extra boost clear up some of the smoke when I romp into it?
Thanks,
~Rob
Old Mar 27, 2006 | 08:01 PM
BigBlue's Avatar
It won't clean up the initial puff since all that is is a lack of air but it will help the top end. You need to go to piersdiesel.com and buy one of their adjustable boost elbows ($20) and install that. That way you can set the boost to whatever you want.
Old Mar 27, 2006 | 08:15 PM
hotdram's Avatar
Thanks man
~Rob
Old Mar 27, 2006 | 10:34 PM
BigBlue's Avatar
No problem. It should be easier than trying to find your crown.
Tyler
Old Mar 28, 2006 | 06:39 AM
hotdram's Avatar
Tyler
You would think
I didn't see a boost elbow on the Piers site, but I think I may go with a manual boost controller instead.
~Rob
Old Mar 28, 2006 | 06:48 AM
displacedtexan's Avatar
Originally Posted by hotdram
You would think
~Rob
TST has them on theirs for $25... http://www.tstproducts.com/index.asp...PROD&ProdID=33
Old Mar 28, 2006 | 07:34 AM
RowJ's Avatar
You would think
~Rob
I have used an MBC and they are slick. Can be adjusted to 1 psi increments... allowing exactly the setting you prefer.
I have one that I'm not using, if you want to try it on Saturday. Very simple to hook up.
RJ
Old Mar 28, 2006 | 07:53 AM
hotdram's Avatar
RJ
Here we go again
(RJ let's me "try" something and I run out and buy it)
Can't wait, I will take you up on your offer RJ.
Thanks,
~Rob
Old Mar 28, 2006 | 01:58 PM
Olratlr's Avatar
I bought one off Ebay $12.50
Old Mar 28, 2006 | 02:03 PM
BigBlue's Avatar
Ehh. I have an externally adjustable wastegate now. Makes life SOOO easy.
Old Mar 28, 2006 | 06:11 PM
Timberman's Avatar
What is the down side to an adjustable elbow? Can you fry your turbo with one? I'd like to find out more about them, I might need one if they are only in the $20 range.
K-80
Jan 29, 2004 05:41 AM
j
Oct 12, 2003 11:25 PM
Mostwanted
Aug 14, 2003 07:43 PM
TPilaske
16
Jan 11, 2003 08:34 PM
frank
Nov 1, 2002 04:34 PM
