turnbuckle
Old Jan 26, 2004 | 05:40 PM
K-80's Avatar
Question turnbuckle
can anyone tell me whay size turnbuckle to use for 98.5 24v
Old Jan 27, 2004 | 10:34 AM
MLR1's Avatar
If i remember a 6 inch buckle will work.
Old Jan 27, 2004 | 10:46 AM
Bob Wagner's Avatar
why do you need a turnbuckle on a 98.5 just use a boost fitting
Old Jan 27, 2004 | 11:10 AM
mcevins's Avatar
Bob,
I think you are right, the hard line on the wastegate started about 2001 didn't it? A boost fooler should work fine K-80. Look on the bottom of the compressor side of your turbo, there should be a rubber hose coming from a brass elbow to your wastegate. That elbow would need to be replaced with a more restrictive elbow sold by many vendors. This restrictive elbow would require more air pressure to open the wastegate, therefore allowing you to build more boost.
Meacham Evins
Old Jan 27, 2004 | 11:34 AM
MLR1's Avatar
Sorry wasn't thinking this morning, you only need a buckle for a 01 or newer Hy equiped autos.
Old Jan 27, 2004 | 05:03 PM
K-80's Avatar
I ordered ez box & gauges from wildcat he said i would need to install a turnbuckle with an auto trans. Maybe he was mistaken .
Old Jan 29, 2004 | 05:41 AM
K-80's Avatar
I e-mailed Rod he made a mistake you dont need a turnbuckle for 98.5
roadranger
Feb 25, 2004 07:46 PM
j
Oct 12, 2003 11:25 PM
Mostwanted
Aug 14, 2003 07:43 PM
TPilaske
16
Jan 11, 2003 08:34 PM
frank
Nov 1, 2002 04:34 PM
