can i weld on my valve cover
is the valve cover aluminum and has anyone welded on one. i put a valve cover breather on it and its not working out i need to cover the hole
. i want an idea if i try to tig over the hole if im going to make a big mess. thanks
Seeing as the cover is Cast alluminum, you'dbest be a darn good welder.
Even so, you will want to remove the cover in order to prevent slag and garbage from dropping down onto the valve train.
Maybe someone else here has tried it and can comment on their success?
if your valve cover is red/silver is was aluminum and you can clean it up REALLY well and weld it with a TIG. the black/silver covers were magnesium and can not be welded on. im sure if you have a magnesium cover someone would love to swap you for thier aluminum.
Sep 11, 2009 03:55 PM
dog rocket
Oct 16, 2007 01:05 PM
