Cam help!!!
Old Oct 17, 2008 | 01:12 PM
dspoon's Avatar
Cam help!!!
Alright guys & girls I need help on deciding weather or not to go with a cam the F1 Helix 2 cam in my setup. See my sig. below. A lot of people have told me thats what I need to bring my egts down they say it's the cheapest bang for your money I am having high egts pulling 1250+
on the grades my camper weights in around 10500 fully loaded water and all. Can everyone please tell me the pros and cons of a cam for everyday driving and pulling
Thanks: Rich
Old Oct 17, 2008 | 01:20 PM
HOHN's Avatar
Cons: cost
Pros: better turbo response, better mpg, lower EGT, broader RPM range.
Old Oct 17, 2008 | 01:21 PM
99globalwarmer's Avatar
it wont help as much as you seem to think yes i lost a little and gained some performance but i could see a turbo charger being the best fix
Old Oct 17, 2008 | 03:00 PM
cstroup's Avatar
IMHO, Yes turbo is a much better and cheaper route. If you have the HY-35 get a HX-35W at least and you will cool alot better. You can find them cheap used or there are other choices in aftermarket that would be better but your back to the cost factor. Bang for your buck is the HX-35W. You will have a big labor bill or some work ahead of you if you with the cam and then will find you still need a bigger turbo.
Old Oct 18, 2008 | 04:10 AM
ratsun's Avatar
x3
Get a bigger turbo or a set of tow twins
Old Oct 18, 2008 | 12:51 PM
S400_12vDiezel's Avatar
IMO staying with the smallest turbo you can for a given power level is best, it makes for better driving because of less lag and easier to clean the smoke up on the lower end.
I would do a camshaft IMO because it as said above will reduce EGT, Smoke and increase spoolup. So basically it will only help, not hurt!
I have a PDR cam that is ground for towing/economy/daily driving I need to sell...
Old Oct 18, 2008 | 12:54 PM
1-5-3-6-2-4's Avatar
x4 upgrade turbo loooong before you need a cam shaft. I found the 2nd biggest EGT helper is getting rid of the stock cast exhaust elbow at the back of the charger. either new charger with a true 4" down tube.
Old Oct 18, 2008 | 02:50 PM
97 D-Tec's Avatar
like 1-5-3-6-2-4 said get rid of that stock exhaust elbow and buy a new charger witha 4inch down pipe..... in just doing those 3 things my egts droped over 200 degrees and obviously i gained hp
etn550
Apr 1, 2010 12:12 PM
AH64ID
Jan 18, 2009 04:59 PM
ILIANBG
Dec 11, 2006 04:49 PM
MikeAgnew
Oct 20, 2006 08:36 PM
James Lucas
28
Sep 1, 2003 03:25 PM
