CAM DECISION TOMMORROW...HELP PLEASE
Old Aug 28, 2003 | 06:24 PM
James Lucas's Avatar
Topic sums it up...
I am doing the fire rings
Head porting
EZ DRAG
I have DDIII's for now
5" exhaust
Twin turbo b1 quick spool b2 combo
DTT Auto with 89% TQ
Now I gotta decide on a cam..... Advice guys please....
James
Old Aug 28, 2003 | 06:27 PM
Jetpilot's Avatar
Re:CAM DECISION TOMMORROW...HELP PLEASE
I really like my PDR cam.
Doug
Old Aug 28, 2003 | 06:42 PM
TxDieselKid's Avatar
I gotta agree with Jet. He has done some WILD stuff to his truck, and I'm sure he researched ALL the possiblities, yet he ended up going with a PDR.
I would do a PDR cam. Since it's a 24v, and you most likely won't be spinning it over 3,500-4,000, then I don't think stuff that is better suited for high RPM range is necessary.
Just my .02, which I'm sure will be shot when Don~ get's on here.
Andrew
Old Aug 28, 2003 | 07:07 PM
Don M's Avatar
DTR Advertiser
Depends on what you want to do. Your goals, etc.
Do you want to stomp everyone else or be like everyone else?
What are your drive pressures gonna be?
Fueling levels?
RPM range?
Drugs?
Camshafts are not an easy thing to develope. Literally hundreds of hours are needed to come up with something that works. I know of only one vendor that has done the homework to make some progress. Diesel Dynamics. I used to think it was 18 cam profile changes they did. Keith now says its up to 21. Dyno comparing them. Road testing them, etc. Many of the cam tricks that others tried did not produce the results they thought it would. Its nice having a dyno in your shop to test and compare changes.
If extreme 12 valve cams are on anyones mind...Im working toward that now. 8620 Billet steel. No prisoners stuff. Not for the faint of heart.
Don~
Old Aug 28, 2003 | 10:44 PM
Heck Don I don't have the answers to most of your questions...
But here is a stab at it.....
1)Stomp everyone else? I can't out spend everyone else but I want to have maximum fun with the money that I am spending...
2)Fueling Levels? Stock Vp44, delivery Valves and I gotta talk injectors soon.
3)RPM Range? I have figure out those limits NOW?????
4)Drugs? I used to smoke pot but grew up...he he
I won't rule out drugs but wanna do as much as I can without it.
So it is PDR, Enterprise, or DD?
Jet Pilot,
PDR is a strong contender so far!!!!
Old Aug 28, 2003 | 10:45 PM
Oh yeah Drive pressure's???? Hell I dunno I am under pressure alot lately especially when I drive
James
Old Aug 28, 2003 | 11:07 PM
Roger rodbolt's Avatar
James,
It would be nice if someone would do an engine dyno comparison of the three cams, noting spoolup, egts, boost, drive pressures, etc. but I know of none such tests. I went with Piers Cam and have been very satisfied. Cost is alway a factor in my household so it was easy to get the PDR. That said, I've not tried the rest.
Larry
Old Aug 28, 2003 | 11:16 PM
I am also doing the Valve springs and retainers on the heads...
Thanks Doug, Don, Andrew, and Larry
I will check this again tommorrow before I make that tough choice...
James
Old Aug 28, 2003 | 11:20 PM
James,
I'm curious as to whose valve springs and retainers that you are using? Larry
Old Aug 29, 2003 | 09:37 AM
Larry,
I am using Titanium Retaners and Titanium and Steel Springs ??? from what I understand... Mark has a supplier for this and I don't know the source. I am sure he would be able to help you out on locating some.
James
Old Aug 29, 2003 | 10:33 AM
moneyman's Avatar
If you buy the pdr cam do you need to change the retainers and spring?
Old Aug 29, 2003 | 10:45 AM
To my knowledge... NO It was just something we decided to do since we were doing all the other head work and the twins.
J
Old Aug 29, 2003 | 03:23 PM
James,
I emailed Mark and it sounds like a really nice setup, the springs, retainers and keepers. Thanks, lc
Old Aug 29, 2003 | 08:49 PM
Your welcome Larry, I don't know much but anything I do I try to pass along.....
James
Old Aug 29, 2003 | 08:51 PM
WELL IT LOOKS LIKE EVERY COMPANY BEING ON HOLIDAY...
forces me to have the weekend to research things a little more on the cam...
That isn't such a bad thing I guess ???
