Braking up on the top end
Old May 2, 2008 | 06:21 PM
pickupman96's Avatar
So with the new injectors the old 35 makes 38lbs of boost and when it gets up into the top it king of brakes up like a v-8 gas thats in need of some points. When its up in that range it still has 8psi or more fuel pressure. What could it be
Old May 2, 2008 | 08:29 PM
anyone????
Old May 5, 2008 | 03:11 PM
JIT's Avatar
JIT
If you have a leak in the fuel system it would suck air and cause the break-up. It will also do it if you have too much timing.
My truck was doing it bad and I couldnt figure it out for the life of me. But it would only do it with the Edge box on. (I had a Juice w/att at the time) Come to find out the previous owner had a Superchips and it was still loaded on the truck... so I was stacking two timing boxes and that was causing the break-up on the top end.
I was releaved because I thought there was something wrong with the Juice and was getting upset with Edge! FYI, bigger injectors will magnify the problem also!
97catintenn
Apr 3, 2012 08:15 PM
RCinMesa
Aug 3, 2011 08:14 PM
horselady
Jan 8, 2008 10:04 AM
mr T
Jun 13, 2007 08:36 PM
