once a day, really bad front end shake while braking
Old Mar 29, 2012 | 09:02 PM
97catintenn's Avatar
Hey everyone, so a few days ago my truck started this really bad shake when braking for a red light/stop sign. But, then for the next stop sign, my truck is smooth. It happens once a day now, everyday...maybe three times. I don't think it is brakes or calipers or rotors. It has to be something else.
Any ideas? When the shake does happen, it feels like it is going to to throw the ladder off my ladder rack and into the ditch 15' away. It's pretty bad.
Old Mar 29, 2012 | 09:24 PM
simplysmn's Avatar
I would say sticking caliper or starting of warp'd rotor
Old Mar 29, 2012 | 09:27 PM
but it happens so rarely. I drive my truck all day as a work truck.
Old Mar 29, 2012 | 09:40 PM
simplysmn's Avatar
but I would still look at the Caliper sound's like if it heat's up it start's sticking
Old Mar 30, 2012 | 12:49 AM
deanhinsley1963's Avatar
New rotors and pads fixed mine.
Old Mar 30, 2012 | 06:20 AM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
Never hurts to just lube the slide anyway. Calipers rarely sieze, its the slide that rusts in place. And maybe you'll see that nice blue sheen on the rotors that tells you its been getting way too hot.
Old Mar 30, 2012 | 07:19 AM
bannerd's Avatar
There is a rubber boot that goes around the piston in the caliper. If these get holes in them it causes the rust to form between the pistons and the brake bore. For the cost of calipers I would just buy the set. Will cost you about $40 for both of them off.
If it's a warped rotor replace them or re-mill it.
Old Mar 30, 2012 | 02:46 PM
diesel402004's Avatar
Front axle u-joints. Mine caused the same issue when they went bad.
Old Apr 1, 2012 | 11:17 AM
Well, I got a little sick to my stomach when I saw this
Old Apr 1, 2012 | 12:49 PM
BigIron70's Avatar
Cummins Guru
Time to beef up the steering gear mount, looks like some hard miles on the old girl.
Old Apr 1, 2012 | 02:20 PM
simplysmn's Avatar
Well now is the best time to ditch all the stock stuff and go crossover you won't ever have to worry about that problem ever again
Old Apr 3, 2012 | 10:14 AM
any thoughts on were to get a replacement?
Old Apr 3, 2012 | 10:55 AM
simplysmn's Avatar
there Hard to find let me see if I have any left but seriouly if you have any type of lift do crossover steeringyou won't ever have to worry about messed up steering again
Old Apr 3, 2012 | 10:56 AM
the mopar PN for the plate is 52037876
www.chryslerpartsdirect.com is who i deal with.
Old Apr 3, 2012 | 10:58 AM
simplysmn's Avatar
Don't believe they have any more in stock
