box or programmer???
Old Mar 28, 2007 | 07:58 PM
garedan's Avatar
Question box or programmer???
i want more power out of my truck but i was counting on you guys to help me decide what to get. there are so many boxes and programmers out there and i dont even know where to start. i want somethin safe for more truck and somethin that wont cut down on the engine life or cause other problems with my truck. i have looked at the edge comp and the bullydog power pup. i aint set on these i just need some input. thanks
Old Mar 28, 2007 | 08:42 PM
dieselbeef's Avatar
Muted User
nice avatar...i got mine first fella. yer welcome
Old Mar 28, 2007 | 11:02 PM
Tate's Avatar
The two I've had are the Edge Drag Comp and the Smarty. The comp was relatively cheap for the power you get. Downside was that it killed my IP. I also wasn't a huge fan of the way it fueled. On the lower settings it would fuel mildly until it 10 psi, then fueled quite hard. Made it difficult to get through a busy intersection quickly without leaving a cloud. Smarty is much more linear in the fueling I find. You can drive on the smoke threshhold without any surprises. Smarty is rated at roughly half the comp, and costs more. But if I had to do it again, I'd still go with the Smarty.
Old Mar 29, 2007 | 12:26 AM
Ph4tty's Avatar
You're gonna want guages before you start adding a box or programmer which makes the edge juice so appealing for many. If you want to set up some mechanical guages then a smarty, edge EZ, or Van Aaken are popular choices.
Old Apr 1, 2007 | 12:30 PM
garedan's Avatar
what would be wrong with the mechanical gauges and a comp? are they not as accurate as the attitude???
Old Apr 1, 2007 | 05:41 PM
Tate's Avatar
Edge Juice is basically the same as a comp, but has gauges included in it. To buy both a comp and gauges, its gonna cost more than the juice, and you have a couple less features as well. Theres nothing wrong with running seperate gauges and a comp, but there is a cheaper alternative.
Old Apr 1, 2007 | 05:49 PM
scottsjeeprolet's Avatar
If i had it to do all over again i would get the Juice w/ Attitude, but it wasn't on the market for your trucks yet. If i would have only waited another 4 months i could have got it. The Juice is cheaper than guages/ Comp.
Old Apr 1, 2007 | 10:24 PM
Ph4tty's Avatar
Cost. Mechanical guages are more reliable than electronic and that way all your eggs aren't in one basket and you're not married to your box =P
I'm just trying to take a break from being a smarty cheerleader Gooooo SSSSSmartyyyyy!!!!.......I feel better now
Old Apr 3, 2007 | 04:30 AM
rednek_boots's Avatar
hey guys for those of you who have the juice w/ attitude, does it come with everything to get readings eg. fuel pressure, boost, egt? ive noticed how expensive even some of that stuff is!!! I think im gonna go ahead and order my juice.....wheres the cheapest place? so for ive found $614
Old Apr 3, 2007 | 01:52 PM
99farmdodge's Avatar
The Edge Juice w/ Attitude comes with everything you need to install it and monitor everything.
04ctd
Oct 5, 2006 08:27 PM
jb903
May 17, 2006 01:21 PM
imfletcher
15
May 12, 2006 08:31 AM
G-NOTE
13
Aug 16, 2005 02:03 PM
fitzer
Feb 28, 2004 05:49 PM
