This boost gauge rattle is killing me
Old Aug 9, 2004 | 08:01 PM
Charlie8301's Avatar
About three months ago I installed a set of Isspro gauges, including a boost gauge. All went well and I was very satisfied, except for this boost gauge noise. So I called Rod from Wildcat, who was more than willing to help, and we tried a couple of things. First we tried a needle valve to slow the flow down, no good. Then we replaced the hard plastic hose with a soft clear hose, no help. Finally Rod sent me a new boost gauge all together, and it's still rattling. It only rattles from about 18-30 PSI, and I’ve pulled it out of the A pillar to make sure it was in the gauge. Does any have any other ideas to try?
Old Aug 9, 2004 | 08:29 PM
Zino's Avatar
Yes, you need what is called a snubber. It is a small volume with an orifice in it. It is used all the time on pulsating reference lines in the power station. I am sure you could find one on ebay cheap. The smallest ones are 1/4" npt, in and out, so you would have to bush it down to 1/8" for your fittings and that might look a little campy, so just hide it under the hood somewhere.
Zino
Old Aug 9, 2004 | 10:54 PM
infidel's Avatar
Needle valve does the same thing as a snubber. Your problem is probably the gauge itself.
Old Aug 9, 2004 | 11:23 PM
dodgediesel4x4's Avatar
If it was the gauge itself, then what are the odds of getting 2 that are bad?? I'd try the needle valve 1st cuz its cheaper, then try a snubber.
Old Aug 9, 2004 | 11:45 PM
Zino's Avatar
You need a little volume. Thats what will smothe it out more so than the needle. A needle valve only restricts flow when there is flow. A gauge is dead headed, there is no flow, other than the flow to compress the airspace in the bourdon tube during a transient.
Old Aug 10, 2004 | 01:02 AM
joefarmer's Avatar
Here's a part number for a CAT brand guage snubber:75-3795. I've heard it works better than a needle valve. If it works, let me know -- I'd like to thank the guy that recommended it to me.
brandon.
Old Aug 10, 2004 | 01:36 AM
duner's Avatar
or you just may have a bad intake valve. i don't think you should have any pulsation at 18 PSI.
Old Aug 10, 2004 | 10:45 AM
BigBlue's Avatar
I can hear an ever so slight rattling at 18-20 on mine. Radio and air have to be off and the windows have to be up to hear it, but it's there.
Old Aug 16, 2004 | 01:02 AM
KATOOM's Avatar
Have you tried replacing a section of the boost line with rubber hose? I hear that stops engine noise from transmitting up to the gauge.
Old Aug 16, 2004 | 01:44 AM
Haulin_in_Dixie's Avatar
Make sure you don't have any fuel in the line that goes to the gage, the trapped air will quiet it.
Old Aug 16, 2004 | 04:22 PM
phox_mulder's Avatar
If he has fuel in his boost line he has more problems then just a rattling guage.
phox
Old Aug 16, 2004 | 04:31 PM
cmckinney's Avatar
My Isspro EV boost 0-30 does the same thing. No issue just pulsation doesn't hurt anything but I could see it as annoying. I think it just let's me know I'm getting good amount of boost without looking at the gauge.
-CM
Old Aug 16, 2004 | 05:20 PM
Thanks for all the help guys, I have yet to try the snubber valve, for now I'll just keep the radio turned up.
Old Aug 16, 2004 | 08:28 PM
phox
OOps, thought we were talking about a fuel pressure gage. Hey, where is the pressure take off, mine is glass smooth. I have the bolt replacement near number five cylinder.
Old Aug 16, 2004 | 08:46 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I drilled and tapped the intake horn when I did my install 3 years ago.
Rock solid, no buzz.
