This boost gauge rattle is killing me
Originally posted by Shovelhead
I drilled and tapped the intake horn when I did my install 3 years ago.
Rock solid, no buzz.
Pretty sure my boost guage is quiet.
phox
Boost gauge rattle
Here is what a fellow from TDR sent me when he was having the same problem.
Hope this helps.
Dave
Dave, I found a snubber from McMaster Carr with a .04 orfice. and 1/8 npt fittings. mounts right on the back of the gauge. worked great and only $6.77 .
Dave
My Autometer gauge doesn't make any noise, but it occasionally will wiggle the needle under high boost (31+) conditions. This makes it hard to read exactly what number it points to. It's a slight wiggle, about 3psi in width. It doesn't happen that often, and since I haven't seen my truck in 3 months, I can't tell you more about when or why it does this.
One thing I ran into was plumbing the boost line. My 1/8" line cracked and started to leak. I couldn't find any replacement in that size, so I went up to 1/4". I figured it wouldn't make a difference since the gauge still has a pretty restrictive orifice on the inlet. The larger line seems to provide a larger "cushion" of air in the gauge feed, and the compressibility of air seems to smooth things out a bit.
Justin
Justin
I ordered a snubber valve today, should be here in a couple days. I'm getting my boost reading from a 3/4 in pipe plug I removed from the head (Driver Side, Rear of engine) , mabe thats my whole problem.
Just to add to the list, I too have the vibration from about 15 and up. In addition I used the plug by number 6.
I may try to tap the horn and see if it helps. If you get the snubber let us know how it works out.
Roy
Roy
I got my snubber today but I have a Couple of questions. (1) what end of my hose do i put it on (gauges side or intake side) and (2) what directions is air supose to flow through it?
Where did you get your snubber?
I have the exact same problem and it's driving me crazy!
Dave
Buff
I got my snubber from the Mcmaster book at work, P/N 3820k11. Im going to put it in this tonight, i'll tell you how it works
Buff
Thanks
Dave
Got my snubber in today. I didnt know where to put it so I first tried right at the intake, it got rid of the noise but the boost gauge was about 4 sec. behind. Then I tried right on the gauge. This kept the boost gauge from being so slow and I still got rid of my gauge niose. FINALLY!!!
Thanks to all that helped
Randy
Randy
