boost gauge problem
Old Apr 30, 2009 | 08:58 PM
BlackRam1's Avatar
boost gauge problem
I installed a new fuel pressure gauge today and I think i cut my boost tubeing when i cut the hole in the fire wall what can I use to fix it? it is currently 1/8 in. O.D air brake tubing. If you think it could be something different let me know, please.
Frank
Old Apr 30, 2009 | 10:27 PM
HotRodTodd's Avatar
Either replace the line or use an 1/8'' compression coupling to repair it.
If you use the coupling, be sure to tie it to something so that its weight is supported and not flapping around.
Old May 1, 2009 | 02:53 AM
jaypry's Avatar
when I did my gauge install I used the same 1/8 th" air line. however I slid it thru a long piece of 1/4" air line for a double layer of protection
gpshemi
3rd Gen All Products
0
Jul 19, 2015 06:25 PM
Tank_66
Feb 28, 2008 08:34 PM
turbomike
Dec 3, 2007 09:31 PM
MoparMarv
May 4, 2006 04:41 PM
CRXsi
Mar 31, 2006 07:56 AM
