Boost Fooler
And the reason I ask is because my truck isnt making much boost and seems to be in a limp mode because it is pulling the p0234 code which is Engine Overboost Condition. When it runs good in makes about 38 psi, right now only about 18 psi, and running bad.
Double check...doesn't the Edge Comp "boost fool" the ECM? If not, then yes you'll need to have the boost fooler installed. Should install inline. If that does not work then you may have a intercooler boot loose/cracked/blown.
Here's an off the wall cool link I just found
http://www.tibor.org/fuel-box.html
Killdmycobra
Nov 12, 2010 05:15 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
rkelley
19
Jan 11, 2007 10:59 PM
GTSDave
Jul 8, 2005 09:06 AM
Palmetto_kid
Jan 16, 2004 02:21 PM
