boost elbow? I think...??'s
Ok... I know the ez is a better module and everything...but I have a superchip max tuner. It was a good deal on ebay so I bought it. Anyway, I don't think it really has a built in boost fooler? I read on here about a guy w/ a supertuner who bought an A.D.D. from
haisleymachine.com and said he then got a lot more boost. Any one else heard about this?
My next question is: should I do anything with the waste gate now? I have heard that with the ez you hook up a boost elbow or something? I have some orfice/restriction tubes I could put in-line or is there something I should buy? Or... am I out of my tree about this whole boost elbow idea??
-Ryan
-Ryan
The boost elbow will bleed off some pressure before it gets to the wastegate actuator- so you can make your own by installing a calibrated orifice in the boost line to the actuator, followed by an adjustable bleed off valve. With this device you can control how much boost the actuator sees.
I don't know whether your module has a boost fooler- does it connect to the MAP sensor?
If not it doesn't have one.
I'd strongly suggest getting an fuel pressure gauge and a pyro for exhaust gas temps!
HTH
AlpineRAM
HTH
AlpineRAM
dodgediesel
14
Dec 14, 2006 09:54 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
