boost elbow ???
Old Mar 1, 2006 | 02:25 PM
mxdsl183's Avatar
boost elbow ???
what exactly does a boost elbow do? ive read that it can help lower EGT's but what exactly is its purpose and is it really worth it?
Old Mar 1, 2006 | 02:37 PM
micah's Avatar
worth it? I bought mine for $15 off ebay.
as for what it does, it blocks off the wastegate so you can get more boost out of the turbo. However, you won't want to use one unless you have a boost fooler, or a box that has a boost fooler built in, otherwise you will throw codes and I believe cause de-fueling.
BTW, the purpose is that as you add more fuel to create more power, you also create more heat. more air is what cools it, so more boost will get more air in the cylinders.
Old Mar 1, 2006 | 02:49 PM
mxdsl183's Avatar
what is a boost fooler? are they hard to install, and about how much do they cost, when you say it creates more heat, about how much, i do a little bit of hauling, a CAT skid steer and cattle, so i dont want any thing to cause to high of EGTs
Old Mar 1, 2006 | 03:52 PM
RowJ's Avatar
Boost fooler tells the trucks computer it is still under 22 psi boost, when it's actually higher. This prevents defueling.
And your EZ has a boost fooler built in.
As explained, boost elbow will allow more boost, which will get more air to cylinders. Block off wastegate completely, until you have enough fuel to hit 33-35 Psi boost. Above that is over heated air and higher EGT's!
Your signature does not mention tranny.... assume you have 5 or 6 speed manual?
RJ
Old Mar 1, 2006 | 04:21 PM
micah's Avatar
sorry, didn't notice you had the EZ installed... doesn't the EZ come with a boost elbow?
Old Mar 1, 2006 | 08:26 PM
mxdsl183's Avatar
i have a 5 speed......sorry! ha, but the EZ came on the truck when i bought it, it the Superchips d-box (i kno its just a relabeld EZ box....lol) but im not sure if it came with an elbow or not, how can i check? im going to upgrade to a comp box in a few months i assume that if the EZ has a boost fooler then a comp does...thanks for your help
Old Mar 2, 2006 | 07:25 AM
micah's Avatar
yep, comp does. How much boost do you get in 5th at WOT with the current setup?
Old Mar 2, 2006 | 02:11 PM
mxdsl183's Avatar
not sure, my gauges will be here tommorow...or supposed to be....i think im just going ot go ahead and get a boos elbow haha.....they r cheap like you said....thanks for the help.....ill post how much boost i get now when i hook up my gauges tommorw or this week end.....
thanks for the help
Old Mar 2, 2006 | 08:24 PM
scottsjeeprolet's Avatar
I bought my EZ off of Ebay and it didn't come with an elbow either, i emailed Edge and told them i needed one and they sent one free of charge.
What a great company!!
Old Mar 3, 2006 | 02:24 AM
CJ's Avatar
CJ
Mxdsl183,
On my 02 the stock elbow was on the turbo(radiator side) at about the 6 o'clock position. The stock elbow screws right into the turbo and has a vacume line running to the wastegate. The stock one is more of a 45 degree angle while the after market is a 90 degree......hope this is not too confusing.
CJ
Old Mar 3, 2006 | 07:20 AM
RowJ's Avatar
Originally Posted by CJ
The stock elbow screws right into the turbo and has a vacume line running to the wastegate. CJ
"Vacuum Line"?? Actually a cool air, Pressure line!
No offense... just don't want any newer members to get confused.
RJ
Old Mar 3, 2006 | 01:12 PM
CJ's Avatar
CJ
RJ
Your're right. It was late and I was trying to get turned around for night shift tonight. Sorry for the misinformation.
No offense taken
CJ
Old Mar 3, 2006 | 02:10 PM
mxdsl183's Avatar
thanks guys, i got one on they way.....
Old Apr 5, 2006 | 01:37 AM
kelownadiesel's Avatar
Hey guys I need a little help.I just finished installing my comp drag and it came with a boost elbow but on my turbo it doesnt look like there is anywhere to put it.The truck is a 01 5spd.I've heard that on autos the wastegate line is solid or something ,but my truck is a manual.It appears that there is a line on the front of the turbine housing at the bottom right but there is no appearant way to get the line off and it is solid.Pics would help immensly.I am only seeing 21psi but the truck still rips
dodgediesel
14
Dec 14, 2006 09:54 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
