Boost elbow
Boost elbow
What is this boost elbow everyone talks about? I saw something on a website last night, they say it's a boost elbow. Looks like a little brass 90deg elbow, threaded on both ends. What does it do?
It's explained pretty well here> http://cgi.ebay.com/ebaymotors/DODGE...Q5fAccessories
SO if I'm understanding this right, I can't use the boost elbow on my truck as that I have the auto tranny and stock turbo? I'm looking into getting a j-hook and boost fooler from bd. Wondering if I should do the elbow or not. I'm only getting about 19psi of boost now.
the superchips tuner doesnt do boost fooling, im getting a smarty asap! borrowed my buddies for the commute to work one time, ( 900miles each way), and it was awesome. wish i would have known of the smarty prior to buying the superchips.
You should verify that you actually have a hy35. I *think* your 01 auto should have a hx35, so the boost elbow will work.
It'll say right on the tag on the compressor housing. And you should be able to see the threads on the stock fitting going into the housing if it's a hx35.
Oh, and I just read that link. I think that guy is mistaken. Technically the hx will develop more pressure/boost, but it is not capable of delivering more flow over 35psi due to adiabatic (compression) heating. Around 35psi the pressure creates enough heat to resist making the air more dense and simply makes it hotter and higher pressure as "Choke point" in the exhaust housing hurts flow since the wastegate won't be letting excessive drive pressure vent.
And that's with a good aftercooler of course, which the stocker is supposed to be pretty decent. Otherwise the number would be more like 15psi topps.
In short, the point of diminishing returns.
Your 2001 came factory with the HY so unless it's been changed after the fact that is what it will have.
As far as hp increase with J-hook, that depends, is the truck making any smoke? If yes, then by increasing boost, more fuel will be burnt and more hp made. The Hy can go as high as 32psi but it will make so much heat it's not really doing much good, so a real world max of 28 or 29psi is good.
The good thing about the J-hook is it will greatly reduce egt's so you can add more fuel without exceeding max egt's of 1250f.
