boost controller install question in 01.5
Old Sep 6, 2008 | 08:57 PM
DodgeRamdiese01's Avatar
hi all, I would like to install a boost controller which i have lying around, now I have tried to read up on this, but haven't found the answer specific to my year truck
i have an 01.5 with a metal tube going from the turbo to the wastegate, do I split that with the boost controller, or am i way off base here? thanks SK
Old Sep 8, 2008 | 05:53 PM
andy2's Avatar
You're on the right track,however it will be tricky to make connections to both the compressor housing and the accuator.The wastegate accuator seals to the comp housing using an o-ring.You could possibly flip the accuator around 180 deg so that its fitting is facing the engine and remove the comp housing to drill/tap it to accept a fitting.I would probably not bother using your type of boost controller on the hy35.I would likely use the other method of controlling boost like using the kit that BD sells (for example) or making your own as others do.
Old Sep 8, 2008 | 07:56 PM
i have a air fitting that you'd find with like pnuematic tools it is pretty heavy duty if I knew how to post a picture I would
Old Sep 8, 2008 | 08:00 PM
19Fury69's Avatar
just get out the vise-grips, or a new turbo. you should be safe clamping it off with vise grips with stock injectors and just the superchips, might touch 30psi
Old Sep 9, 2008 | 06:38 PM
bpollard1248's Avatar
will the clamp work on an auto tranny truck because with my comp i can only get 20psi
Tank_66
Feb 28, 2008 08:34 PM
Billm2004
18
Jan 17, 2008 05:02 PM
chevellePuller
Dec 12, 2005 07:58 PM
tdupuis
Oct 1, 2004 10:49 PM
admin
24
Mar 10, 2003 12:58 AM
