blowing turbos?????
Old Jul 5, 2011 | 11:12 PM
1dumrednek's Avatar
blowing turbos?????
im workin on a truck for a buddy here. it blew the stock turbo about a month ago. we put my stock one on and he got about 100 miles before that one blew too. what could be taking them out? oil feed line isnt restricted and drain tube isnnt either. we got a hx35 hybrid to put on but gotta find the problem first. any ideas?
truck: 2000 2500 5 speed edge j/a, bhaf, 4 inch exhaust
Old Jul 6, 2011 | 09:56 AM
infidel's Avatar
Could it be they were the counterfeit Chinese turbos labeled Holset and sold for cheap on places like ebay?
Watch one blow up> http://www.myholsetturbo.com/video.html
Old Jul 6, 2011 | 01:14 PM
1dumrednek's Avatar
both were original turbos with over 350k on them. the second one came off my truck and was fine when it went in
Old Jul 6, 2011 | 01:15 PM
Tate's Avatar
What specifically went wrong with the turbos? Lock up, become excessively loose, did the wheels actual scatter? Knowing that will help diagnose your issue.
Old Jul 6, 2011 | 01:25 PM
1dumrednek's Avatar
oh sorry. theyre excessively loose. just wears the bearings out right away
Old Jul 6, 2011 | 01:44 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Is your buddy barking the turbos? letting off them real quick under heavy acceleration and causing them to bark? That will damage a turbo in a hurry.
Old Jul 6, 2011 | 03:18 PM
lovinCTD59's Avatar
Be sure your not runnin a Fram or other cheap knockoff oil filter. Turbos hate small paper particles too!
Old Jul 6, 2011 | 10:10 PM
Tate's Avatar
If its loose axially, turbo barking/surging would be the likely cause. Radial play would probably be due to bad oil condition or supply.
How loose is loose? Can you measure the play?
Old Jul 7, 2011 | 01:39 PM
1dumrednek's Avatar
its up and down play. looking into it last night, the oil was low. there was only like 6 litres in it. thinkin that was the cause. it wouldnt surprise me if hes barking it. my new turbo barks every time i shift if im driving it any bit harder than normal.
Old Jul 7, 2011 | 02:34 PM
Lil Dog's Avatar
Oil supply is the key to keeping your turbo alive longer. Cheap oil, low oil, pinched lines all can cause them to die fast. There is damage to the engine too, but the turbo is more sensitive.
Barking is bad, mine does it more too, but I have been working on the fueling settings to help keep that to a minimum. I am just starting on the journey of a turbo overhaul.
Old Jul 7, 2011 | 05:24 PM
Tate's Avatar
That would be radial play. Are the wheels touching the housings?
Old Jul 8, 2011 | 09:37 AM
infidel's Avatar
Side to side play is ok as long as the wheel doesn't hit the housing.
Back and forth play is a no-no.
Old Jul 8, 2011 | 09:48 AM
1dumrednek's Avatar
Ya the wheels were touching the housings
Old Jul 8, 2011 | 01:31 PM
1dumrednek's Avatar
Put the new turbo on' fired it up and pulled the drain tube off the turbo and there's lots of oil coming out the bottom. I'm thinkin low oil was his problem. Took it for a short drive last night, seems to be workin fine.
dditt0635004x4
13
Feb 7, 2007 12:36 PM
BigBlackBeast05
Jul 24, 2005 09:47 PM
1320
30
May 31, 2003 01:01 AM
Palmetto_kid
Jan 20, 2003 06:01 PM
