Blew my first head gasket !!!
Old 09-04-2006, 05:03 PM
Sea01Cummer's Avatar
Level6 + Water Meth + defuel and warnings turned off + 7% 5 mile hill = Blown Head Gasket. Time for studs . Anyone have any recomendations on what brand or type of head gasket to use?
Steve
ps. Water Meth kit for sale, 3 weeks old.
Old 09-04-2006, 05:06 PM
getblown5.9's Avatar
do you plan on adding anymore power?
if ill suggest go ahead and have a good quality machine shop o-ring your head, stick a .020" over marine gasket in there, with some ARP 12mm studs and you should be fine for a long time
i am in the process of doing all this work myself, and it aint cheap, but when you see it, you will know why.
cost of work- $2,000
peace of mind- priceless!
good luck
Old 09-04-2006, 05:14 PM
I don't plan to go any higher, i actually plan to lower it a bit. I am going to buy a older play toy and use the current truck as a tow rig.
Steve
Old 09-04-2006, 06:13 PM
Forrest Nearing's Avatar
PM me a price on the water/alky setup!
Old 09-04-2006, 07:43 PM
BCB
BCB's Avatar
Same here!
Old 09-04-2006, 08:25 PM
Registered
blackdiesel's Avatar
yall are gunna get busted for sellin stuff in the forums
Old 09-04-2006, 08:42 PM
The ps thing is a joke but i am serious. The reason for the thread is to get ideas for which gasket people are using.
Steve
Old 09-04-2006, 09:32 PM
like i said...a .020 over marine gasket is some HEAVY DUTY stuff...its gotta be twice the weight of the stocker, lots of metal, thick rings for sealing the pistons. goes for right about $200 and worth it
Old 09-04-2006, 09:55 PM
I wish i would have found out the marine was only 200.00
I just won this http://cgi.ebay.com/ebaymotors/NEW-U...QQcmdZViewItem
Steve
Old 09-04-2006, 10:24 PM
GlennRMK's Avatar
What kind of boost were you running?
Old 09-04-2006, 10:56 PM
I'm not sure, i wasn't watching, the road was kinda curvey and i had my eyes on the road.
Steve
Old 09-04-2006, 11:12 PM
sell that stocker to someone and buy a marine gasket
Old 09-05-2006, 07:27 AM
Jetpilot's Avatar
The Marine gasket for the 12v will not just "fit on" our engines, it needs to be modified to fit. A marine gasket that has been modified can be purchased for around $200.
Doug
Old 09-05-2006, 08:43 AM
Pooter's Avatar
Blew mine on my '97 with 43psi, 250k on the original head gasket...
Didnt even know it till the radiator leak turned into a oil leak when I pulled in the driveway
Ran just fine too, popped it a few miles before I got home, temps didnt go up, no loss in oil pressure, just oil puked everywhere
Went with studs/marine gasket(dont plan on anymore boost)
Still running strong....
Old 09-05-2006, 09:56 PM
I got studs and cummins stock gasket coming tomorrow, i plan on tuning this truck down a bit. I wanna get a 12v this winter to hot rod.
Steve
Quick Reply: Blew my first head gasket !!!
