Black smoke
Old Jan 2, 2006 | 04:01 PM
jj3500's Avatar
Black smoke
This maybe an uneducated question but here goes. Why does my truck with the following mods make smoke but then clears up when higher in the revs. Then I watch all these other trucks in videos etc. They are blowing smoke for what it seems is just as long as they want to.
Is my truck not as heavily fueled as those others or what?
Thanks for the education.
Old Jan 2, 2006 | 04:10 PM
squirlchasr919's Avatar
I'm not the most educated on here but I think I can give you a fairly good answer.
The trucks in the videos, sled pullers I assume, are usually purpose-built. They don't have to run on the street and pass inspections and the like. As such they dump in as much fuel as they can with exotic pump setups, huge injectors, and more. There is so much fuel in them that they can't burn it all even with the multiple turbos they have hanging off them.
Your truck produces a cloud until the turbo builds enough boost to even out the air/fuel mixture in the combustion chamber, and the smoke fades out.
Just put on some monster injectors and you'll have the constant cloud like they do, just keep an eye on that EGT gauge, black smoke usually equals heat.
Old Jan 2, 2006 | 04:37 PM
99 cummins's Avatar
As cool as smoke may look it means nothing in the actuall performance. All it is, is more fuel than you have oxygen enough to burn, wasted fuel and power. It soots up your exhaust, makes a mess of your truck and pisses people off. Sooner or later enough of them to put an end to our beloved trucks. If you wanna look cool on a budget just clog up your air filter.
Old Jan 3, 2006 | 11:00 AM
infidel's Avatar
If you want to look even cooler throw money out of your window since black smoke is just money out the tailpipe.
Old Jan 3, 2006 | 01:32 PM
blackdiesel's Avatar
Registered
im sure every body else would like the money instead of the black smoke too
Old Jan 3, 2006 | 02:42 PM
heavyboostin's Avatar
smoke clears because you are meeting the desired air fuel ratio, before the point where you start getting boost, your motor is burning( or lack there of) more fuel than air causing incomplete combustion. Once the desired amount of air meets the given amount of fuel then things clear up, unless you have a 12v with rediculous dv's then it just smokes all the time...
Kevin
Old Jan 3, 2006 | 04:37 PM
99 cummins's Avatar
I hope nobody out there really took me serious when I said to clog up their air filter to make smoke. Just to be clear, I was joking, get those rags out a your intakes.
Old Jan 3, 2006 | 05:59 PM
AggiePhil's Avatar
You guys are making me sad. I want black smoke. Badly.
Old Jan 3, 2006 | 06:04 PM
Meeeee toooo, but first I need to get a fass or something along those lines to atleast slow down the death of my vp....
RJOS
16
Sep 3, 2007 09:19 PM
BuildingBoost
Mar 25, 2007 07:46 PM
BlackSheep5
Nov 27, 2006 07:52 PM
bensdad_canada
May 9, 2005 10:56 PM
dhe9
Nov 14, 2003 07:31 AM
