biggest injector?
Old Jan 16, 2007 | 10:51 PM
cowboy717's Avatar
biggest injector?
i'm wantin to know whats the biggest injector you guys would run with a smarty/tst stack with the stock turbo???
or would i need to upgrade?? and what would be a good one to upgrade to,,?
wantin to get,,, but keep it drivable and get reasonable mileage.
,,, with 315's
thanks
Old Jan 17, 2007 | 05:37 AM
displacedtexan's Avatar
I would think that with a Smarty/TST you could bury the pyro now, what are your EGTs like?
Maybe some Mach 1s?
And bump
Old Jan 17, 2007 | 07:18 AM
blackdiesel's Avatar
Registered
You already need more air, how's your tranny's holding up?
Old Jan 17, 2007 | 09:20 AM
cowboy717's Avatar
trannys doin good, haven't had any troubles with it yet since rebuild, but haven't got any gauges on it yet gotta get them ordered this weekend,
Old Jan 17, 2007 | 12:14 PM
BOILERMAKER's Avatar
I had (still have) Mach 2's with the stock turbo and it wasn't THAT bad. That turbo would SCREAM in a hurry though. Of course, I have the 6speed and that may make a difference.
Old Jan 17, 2007 | 01:14 PM
dzlfarmboy's Avatar
I think Mach 4's would be to much for towing with an Hy-35 that 9cm exhaust housing wouldn't be able to keep it cool enough it might be possible if you had a manual tranny with the hx-35 12cm housing. just my oo cents
Old Jan 17, 2007 | 01:15 PM
aggiehorsepower's Avatar
what he said
Old Jan 17, 2007 | 02:28 PM
Big Smoky's Avatar
Before I got the B2, I was running 200hp injectors with the comp and it would get HOT! But I could also control it surprisingly. I'm still overfueled with the B2, but it's a lot better!
Old Jan 17, 2007 | 02:45 PM
Ohhhhhhhhhhhhhhhhh yeah, forgot all about that darned HY he's got.
Old Jan 17, 2007 | 03:39 PM
Registered
,,, with 315's
thanks
stock turbo? stock injectors are more than enough
upgraded turbo? you could run as large as mach 7's if you want to put a silverbullet on your truck, or even a set of twins.
The easiest way to decide is to see how much you want to spend. Then we can go from there
Old Jan 17, 2007 | 04:31 PM
Gotlift01's Avatar
I wouldn't do injectors either with the stock turbo....mines stock and even with my COMP it will get hot pretty quick.
~Nick
Old Jan 17, 2007 | 05:07 PM
Mike Holmen's Avatar
The Guru
I ran 90rwhp injectors and a edge comp box. It worked well. Egt's where hot when towing but just take your foot out of it. Whats your boost pressure? I pulled 38psi with my old HY turbo. Your gonna need to think about getting more fuel to your VP pump. Which box you running to get 150hp? The best fueling boxes typically pull about 125 to 135rwhp.
Old Jan 18, 2007 | 02:09 AM
Ph4tty's Avatar
Its a 50/150 puck
Oldschooldodge
Jan 10, 2010 05:54 PM
Deezle1
Mar 13, 2005 06:35 PM
24
Nov 25, 2002 07:55 PM
hellotbone
16
Nov 6, 2002 03:18 PM
