Bigger Tires and Rims
Old Nov 20, 2003 | 10:50 AM
crobtex's Avatar
I would like to give my truck a little more axel clerance. What effect would changing out my 16" for 17" or 20" tires and rims? ???
Speedo? Brakes? Gears? ??? ??? ??? ???
CR 1999 2500 4X4 5 Spd
Old Nov 20, 2003 | 11:22 AM
Cowhand's Avatar
Re:Bigger Tires and Rims
Depends on what size tire you put on. Speedo will be off. Gears, depending on what you have now, shouldn't be a problem. I run 37's with 4.10 gears and I'm not going to change.
I wouldn't run anything bigger than a 17" wheel. I've seen a Dodge 4X4 with 20" rims and big street tires and it was the silliest looking truck I ever saw. On top of that, if you go with anything bigger than a 16 or 16.5 rim, you're really limiting your choice of tires......
Old Nov 20, 2003 | 07:11 PM
gandrews's Avatar
19.5” rims and tires look nice though a little pricey.
Check these sites out.
Rickson is a direct bolt on, but the other two require adaptors.
http://www.ricksontruck.com/
http://www.dualdesignsinc.com/
http://www.chromewheel.com/
I have read and heard that Alcoa is going to get into producing 19.5” wheels for dodge lug bolt patterns.
Good luck
Old Nov 20, 2003 | 07:27 PM
crobtex's Avatar
Thanks for the info
I didn't know these things were so pricey :-[ :-[ :-[
Old Nov 21, 2003 | 08:48 AM
Evildiesel's Avatar
Heres my truck with a set of 18" rims with 35's on it. I think 37's would look better though and am saving up for them
[img height=400 width=500]https://www.dieseltruckresource.com/yabbse/gallery/albums/userpics/PICT0063.JPG [/img]
Old Nov 21, 2003 | 09:43 AM
PHX_ATC's Avatar
Good looking truck.
I love the flames. Course I'm rather partial to flames. ;D
Old Nov 21, 2003 | 10:06 AM
crobtex's Avatar
Nice truck and boat!
cr
Old Nov 21, 2003 | 11:26 AM
Cowhand's Avatar
Oops, I stand corrected. I forgot all about the Ricksons, et.al.
Not particularly partial to 'em myself, but the truck I was talking about had what is commonly referred to as "dubs" and low profile street tires.
I'd still stick with a 16 or 16.5 rim. Gives you the widest choice of brands, sizes, and tread patterns. Maybe in a few years that will change, but for now, the choices in an off road tire for 17-20" rims is pretty limited.
Evildiesel - have you found a 37" tire for an 18" rim? The biggest I've found for an 18 is the 35 your running now......
May 29, 2009 10:24 PM
R & A Equipment
Feb 26, 2007 11:27 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
