Bigger Tires
Old Dec 27, 2004 | 11:34 AM
Dieselcamper's Avatar
Bigger Tires
what are the biggest tires you can put on a 2WD.
I have the stock alloy wheels and will be installing
a 1.5" front leveling kit. I want no rubbing.
Old Dec 27, 2004 | 11:47 AM
firestorm's Avatar
I have a minor rub at full steer, tire corner rubs plastic wheel liner slightly, with 315/75/r16 and a 2 1/2" lift in the front. 305's would probably give you no rub, or trim the plastic liner like I have planned.
Old Dec 27, 2004 | 12:22 PM
Did you install the leveling spacers yourself. If so,
how hard was the installation ?
Old Dec 27, 2004 | 06:26 PM
ride_a_hd's Avatar
These look pretty good!
Bridgestone Dueler A/T Revo tires
http://www.tirerack.com/tires/tires....White+Letters&
Old Dec 27, 2004 | 06:43 PM
phox_mulder's Avatar
Re: Bigger Tires
Key word is 2WD.
2 wheel drive, not 4 wheel drive.
No idea, as I've never owned a 2wd truck.
phox
Old Dec 27, 2004 | 07:49 PM
firestorm's Avatar
Yes, it was not that hard at all.
1: Jack up the truck until the wheels are 4" off of the ground. Put the jackstands under the frame, not the lower control arms.
2: Remove the tire.
3: Remove the brake caliper and tie it up out of the way.
4: Place a jack under the lower control arm, and apply slight tension.
5: Remove the shock completley, you may need longer shocks, I did.
6: Without damaging the parts or boots, remove the tie rod end, and upper control arm, from the spindle.
7: Carefully, lower the jack all the way. Make a note of where the coil end sits in the lower control arm, it needs to go back in the same place.
8: Replace the rubber isolator on the top of the coil spring, with the new spacer.
9: Re-assemble in reverse order.
10: Repeat steps 2-9 for the other side.
The truck's front end will need to be re-aligned. Drive it to the shop on the old tires. Let the shop mount and balance the new tires, and do the front end alignment.
Old Dec 28, 2004 | 11:35 AM
Whats involved with seperating the upper control
arm from the spindle. Are any special tools required ?
Old Dec 29, 2004 | 04:29 PM
So if 305's will fit with no rubbing,whats the best tire
brand and deal. I'm looking for a semi-aggressive tred and
good wear qualities. I have a Les Schwab down the street.
Old Dec 29, 2004 | 04:56 PM
firestorm's Avatar
Here is how I did it:
Remove the upper ball joint nut, and then put the nut on about three turns (this will keep everything from falling apart unexpectedly. Place a pry bar between the spindle and upper control arm. Apply moderate pressure, and smack the spindle with a hammer, on the side, where the ball joint is mounted. The ball joint should just pop loose.
Old Dec 30, 2004 | 05:17 AM
95ram's Avatar
If Les Schwab is just down the street from you I'd look into wildcountry TXR's. I have them on my pickup now and like them moer the I liked my bfg mt's. They seem to be wearing better then the mt's and have better traction on wet pavement, snow, and ice. I burnt my bfgs off in 20,000 miles because I couldn't get traction. The turbo would kick in in third gear and the *** end would swing around on wet pavement.
May 29, 2009 10:24 PM
R & A Equipment
Feb 26, 2007 11:27 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
goin
Aug 8, 2003 05:14 PM
