BHAF question
Old Feb 27, 2011 | 05:05 PM
mini14's Avatar
have had mine on for 7 years now with the heat sheild that i fabd. before the bhaf everytime i changed the oil filter and inspected the turbo blades, they were allways covered in gunk, after the bhaf its allways clean.https://www.dieseltruckresource.com/...n&onlynewfaq=1
just make sure to cover the ac line with rubber hose or it will rub thru.
Old Feb 27, 2011 | 05:34 PM
SIXSLUG's Avatar
Also if you decide to run the BHAF, make sure the posts for the stock box don't rub a hole in your new filter or you will suck dirt in a while before noticing it!
Didn't happen to me but someone around here posted up that it happened to him..
If you really want a heat shiled get a piece of cardboard about 18" square and bend it into place and outline where everything is, then cut out a shield using this as a temp.
Old Sep 23, 2012 | 04:30 PM
iwhitne's Avatar
i got a K&N drop in filter for $25 on ebay and made the bottom of my stock box look like swiss cheese with a 1" paddle bit... plenty of air! why spend $40+ on the BHAF?
Old Sep 23, 2012 | 08:52 PM
Marine's Avatar
Veteran: Marine Corp
Hey guys,
I think I may have the template for the heatshield. Someone send me a PM so I remember to look.
Thanks!
Old Sep 24, 2012 | 10:00 AM
Marine's Avatar
Because the BHAF filters way better and has less upkeep.
From my torqued out reuterbender
Old Sep 24, 2012 | 08:53 PM
iwhitne's Avatar
but if you get the BHAF then you can't do the hole in the fire wall trick?!... not sure if yall saw that mod.. but they say something about positive air pressure at the cowl and by punching a hole in the firewall and running a tube from the stock box to the hole is like having force induction..... I don't buy it, but hey to each their own
Old Sep 24, 2012 | 09:17 PM
Marine's Avatar
You can still cut the hole in the cowl. I'll try to remember to take a pic and post it. I use an Amsoil 4050 now, before that was a Scotty II and before that was the BHAF.
Sent from my torqued out reuterbender
Old Sep 25, 2012 | 01:40 PM
Marine's Avatar
Ok I have the template; how do I load it on here? Top, can I email it to you and you can put it in the tech area?
Old Sep 28, 2012 | 02:00 PM
Dane's Avatar
Originally Posted by blackimpala
I don't think adding a high flow air filter is going to do much for a stock engine other than maybe a small EGT reduction.
Old Sep 30, 2012 | 11:46 AM
klcammie's Avatar
hey great article. I was very suprized.
Rickcher
Sep 2, 2009 05:08 PM
Ace
Oct 31, 2007 06:46 PM
Farmer
Dec 3, 2003 11:49 AM
berner
Oct 11, 2003 07:12 AM
McGyver
Dec 14, 2002 09:34 PM
