BHAF to K&N Compared
Old Jun 2, 2003 | 07:43 PM
Homestead's Avatar
I've been running an open element K&amp;N filter for awhile now and have liked it. It is about 7&quot; in diameter and 9&quot; long. It is the filter that comes with the BD-Power X-Stream filter system. Nice unit, but not worth the dollars you pay for it. <br>With all the threads lately about the BHAF, I converted.<br>HUGE difference!!!!<br>After converting, I have less smoke, less noise :'(, truck seems to pull a little harder about mid range, and most of all, I had about a 75-100 degree drop in EGT!!! Not sure on mileage just yet, but it seems to be slightly better, I'll know for sure when I refuel.<br><br>I would never have guessed that it would make such a difference. Next step is a Scotty though.<br><br>Just thought I'd let you guys know.
Old Jun 2, 2003 | 10:32 PM
HeberRam's Avatar
Re:BHAF to K&N Compared
Homestead...check-out the link:<br><br>http://www.dodge-diesel.org/yabbse/i...threadid=15375<br><br>I will shortly have a &quot; giant&quot; hole saw for your use in the near future. : : :<br><br>Steve
Old Jun 2, 2003 | 10:45 PM
Homestead's Avatar
Hey HeberRam<br><br>I already have the hole saw and even now, I'm tempted to cut the hole!! I'm sure that even with a BHAF, drilling the hole will be an added benefit with regards to more air at least around the filter.
Old Jun 3, 2003 | 12:11 AM
HeberRam's Avatar
Homstead...You may want to check with scotty, or some other members, exactly where the hole goes, so when you get the Scotty 11, you won't be trying to plumb through the fender..
Old Jun 3, 2003 | 09:20 AM
dhe9's Avatar
hello,<br>i have been running a K&amp;N for about one year now and it seems to do pretty well. i need your advice on BHAF instead of K&amp;N. will the BHAF void warranty? is it a drop in filter like the K&amp;N? throw it away when dirty or wash? how often should i change it out? who likes the K&amp;N and who likes the BHAF?<br><br>thanks,<br>david h
Old Jun 3, 2003 | 10:04 AM
Shovelhead's Avatar
Administrator / Scooter Bum
I went from the K&amp;N drop in to the Scotty II.<br><br> ;D Happy customer ;D<br>
Old Jun 3, 2003 | 12:27 PM
phox_mulder's Avatar
[quote author=david h link=board=7;threadid=15443;start=0#145203 date=1054650032]<br>hello,<br>i have been running a K&amp;N for about one year now and it seems to do pretty well. i need your advice on BHAF instead of K&amp;N. will the BHAF void warranty? is it a drop in filter like the K&amp;N? throw it away when dirty or wash? how often should i change it out? who likes the K&amp;N and who likes the BHAF?<br><br>thanks,<br>david h<br>[/quote]<br><br>The BHAF is just that, a Big Honkin' Air Filter.<br>It hooks on the end of the intake hose, where the stock box is currently, you remove the stock air box and stick in the attic.<br>I think the filter fiasco is in regards to any higher flowing aftermarket filter, anything other than the OEM Mopar.<br>The BHAF is a dry paper filter so you won't have the oil problem seen with some other oiled filters. <br>Here's some pics of it, borrowed from DeWain (DPG) and BigBlue.<br><br>phox<br><br><br><br>[img width=500 height=400]https://www.dieseltruckresource.com/yabbse/gallery/albums/userpics/Engine.jpg[/img]
Old Jun 3, 2003 | 01:28 PM
erics76's Avatar
I've got an open element K&amp;N, and I've never had a problem with it. People have said they've had oil on their turbo blades, but If you oil it properly and let it drain the excess off, its fine. I will probably go to a scotty II later because it's a better design than just the open K&amp;N.
Old Jun 3, 2003 | 03:05 PM
dhe9's Avatar
so where do you buy the scotty II and is it a drop in like the K&amp;N? high flow? void warranty? BHAF high flow?<br><br>thanks,<br>david h
Old Jun 3, 2003 | 03:09 PM
Shovelhead's Avatar
I bought my Scotty from one of our own fine, upstanding site sponsers.
www.wildcatdiesel.com
Give Rod a call.
He'll answer all your questions.
Ed
Pa outlaw
Aug 25, 2010 10:32 PM
TreeFarm
Feb 15, 2008 12:19 PM
DF5152
Aug 30, 2003 08:49 PM
DF5152
Jul 9, 2003 03:16 PM
midwestdually
Dec 12, 2002 06:18 PM
