Bhaf
Old Feb 11, 2006 | 10:35 PM
WalkerMike98's Avatar
Bhaf
How much of a gain in horsepower and fuel mileage should be expected over the stock filter box. Also, where do I find the prefilter that fits over the BHAF. Thanks
Old Feb 12, 2006 | 12:16 AM
Bart Timothy's Avatar
The BHAF will give no gain in power or mileage over the stock air box. The stock air box is good to over 500 hp when the rubber fender boot is removed.
Old Feb 12, 2006 | 04:11 PM
98ISURAM's Avatar
I just installed the BHAF the other day and have not yet had the chance to run a tank of fuel through it to see if it helps mileage at all. The only real difference that I see so far is that it might help throttle response a small amount and if you have your silencer ring taken out it will make your turbo considerablly louder and allows it to spool earlier in the rpm range. The pre-filter can be ordered from www.outerwears.com and the part # is wr-3325-105.
Feb 22, 2024 07:16 AM
Rickcher
Sep 2, 2009 05:08 PM
Marine
113
Nov 6, 2007 06:24 PM
Ace
Oct 31, 2007 06:46 PM
