BHAF
Old Mar 13, 2003 | 11:30 AM
bkay's Avatar
BHAF
Thinking about going to the BHAF where can I get the turbo/filter heat shield? I did notice last time I cleaned my filter that my turbo vanes had an oily residue on them.
Old Mar 13, 2003 | 11:58 AM
KC's Avatar
KC
Re:BHAF
Make it your self for under $10.00! Installs in mins!<br><br>KC
Old Mar 13, 2003 | 01:10 PM
BradN's Avatar
Re:BHAF
The template for the heat shield is in the Tech Facts section. Get you some 18ga. sheet metal and have a ball! ;D
Old Mar 14, 2003 | 03:31 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re:BHAF
[quote author=bkay link=board=7;threadid=12219;start=0#115505 date=1047576653]<br>Thinking about going to the BHAF where can I get the turbo/filter heat shield? I did notice last time I cleaned my filter that my turbo vanes had an oily residue on them.<br>[/quote]<br><br>The next time you clean your filter, use a little less oil on the filter and wait for it to wick through the filter. Maybe try a very light application, and wait a few minutes to see if the filter changes color all over (including inside the filter). If it does, the filter is properly oiled and you're off.<br><br>Using too much oil is an easy trap to fall into (I've done it myself), but when the filters are lightly oiled, they'll work just as well as heavily oiled, and you won't get the residue on the veins.<br><br>Rod
Old Mar 14, 2003 | 07:38 AM
bkay's Avatar
Re:BHAF
The other reason that I am considering changing is the type of driving I do. Idling through pastures is mighty dusty here in the summer and fall. Also I travel our county roads alot which for all intenys an purposes are dirt roads.
Old Mar 14, 2003 | 09:31 AM
Push Rod's Avatar
Re:BHAF
I certainly do understand dirt roads. My other hat is that of a cattleman, and my trucks typically spend 75% of their time offroad, doing exactly what you say. The first Scotty system I ever bought from Scott, I had the exact same concerns. One of the things I noticed with my stocker airbox is that I often had fine particles in the turbo inlet hose, usually during harvest season (there is NO dust finer than barley dust :'( ). The first year I ran the Scotty, I noticed that there wasn't a single piece of dust in the inlet tube. As well, testing in the oilfields in Alberta this summer (very dry conditions) and the desert in Arizona revealed oil analysis results exactly the same as the stock air unit.<br><br>Rod
Old Mar 14, 2003 | 10:17 AM
bkay's Avatar
Re:BHAF
What are the NAPA part #s for the BHAF/
Old Mar 14, 2003 | 04:41 PM
BradN's Avatar
Re:BHAF
The NAPA part number is 2790.
Old Mar 14, 2003 | 05:42 PM
Mostwanted's Avatar
Re:BHAF
if I go to napa with this part # what will I get? I figured just a filter that attaches to the end of my turbo inlet tube. Are I correct, or do I need anything else?
Old Mar 14, 2003 | 05:54 PM
scottrod's Avatar
Re:BHAF
That's what you'll get. Some people put a stiffener in also. I ran one with no stiffener and had no problem. Personally, I would save the 40- 70 bucks your gonna spend on the BHAF and invest it in a Scotty 2 or Mega Cannon and be done with it. You WILL get rid of the BHAF eventually in favor of something else anyway- we all do....
Old Mar 15, 2003 | 01:13 AM
ATEAV8GN's Avatar
Re:BHAF
Bkay,
go talk to Dempsey at napa and tell him you want the big filter I got and he'll hook ya up, at half the list price too
As for the shield, print out the template, tape together the pieces, got to Lowes for sheetmetal (might not need to, prolly got what you need at the barn,although diamond plate would be awesome) Or, heck, I'll give you my shield once my Scotty II gets here in a week or so 8)
Let me know if you need some info..
p.s. hope ya'll got tkay's kdp fixed :'(
Old Mar 15, 2003 | 03:33 PM
nevrenufhp's Avatar
Re:BHAF
To fulfill a curious question, does a BHAF out flow a K&amp;N drop in?
Old Mar 15, 2003 | 04:01 PM
BigBlue's Avatar
Re:BHAF
Let me fulfill your curious question, yes.
Feb 22, 2024 07:16 AM
Rickcher
Sep 2, 2009 05:08 PM
Marine
113
Nov 6, 2007 06:24 PM
Ace
Oct 31, 2007 06:46 PM
