Best Way
Best Way
I was thinking of changing my gear ratio nto 4.11. A service manager said I would be better off with a 4 or 5 inch exhaust and a program. I just want a little more to get my 5th wheel moving easer. What is everyone's thoughts?
I am not happy with the predator. It makes my truck buck and cut out and smokes real bad when that happens. I can't tell the diff while towing. I would make someone a good deal for it.
I like my 4:10s for daily driving. I run alot off interstate hwys too. MPGs are good, truck takes off really fast in all situations. Rpms are generally 2100-2500 on the hwy, 2500rpm being around 85 mph. I am a BIG believer in spinning more rpms vs lugging the engine. Also I do have 285s tires.
Its not bad to change gears in a 2wd but a 4wd its twice the money. You should see what everyone uses in the towing and hauling forum. There are alot of guys pulling BIG 5th wheels wit the same truck you have.
When I had my Dakota 4x4 I looked into changing the gears to 4.10s and the prices were anywhere from $1000 to $1200.
You can buy alot of power adders for that. And a set of injectors.
There are times when spinning the engine up it ideal. But there are also times when lower RPM are appropriate.
I like to think that there is a happy middle ground. The engine needs enough load to keep temps up and burn off impurities, and high RPM running empty is a pretty light load.
Conversely, you don't want excessive load on the engine, as that is damaging from high EGT and high load-per-revolution.
IMO, the higher the load, the higher the RPM should be. Fortunately, aerodynamics usually does this work for us automatically
600 Megawatts
26
Jul 14, 2005 06:04 AM
Dodgezilla
17
Apr 9, 2003 11:42 AM
admin
27
Nov 12, 2002 04:47 PM
