6 way round to 7 way blade no worky
Old Oct 17, 2009 | 12:59 AM
Mountaineer's Avatar
Like it says. The trailer is a 6 way round, so I go and get a adapter, plug it in and wala ..... no lights or anything.
Ahhhh. Help.
Old Oct 17, 2009 | 02:27 AM
Jeff in TD's Avatar
Are the trailer's lights known to be good?
Old Oct 17, 2009 | 11:23 AM
cLAYH's Avatar
Are you only using this trailer on your truck? If so remove the 6round plug and install a 7 way to match your truck and ditch the adapter.
Old Oct 17, 2009 | 11:52 AM
torquefan's Avatar
Usually there is a poor connection and you simply need to spread the pins slightly on one plug or the other then everything will work together properly, provided both your connectors are wired to code. While on the subject, I'll point out that there are two accepted ways to wire a six-pin connector. One way uses the center pin for brakes, the other way uses the center pin for 12V power. All other pins are the same. On many of the six-to-seven pin adapters, they offer a way to disassemble the connector and swap the wires between those two pins.
Old Oct 19, 2009 | 12:37 PM
davidj54's Avatar
6-ways have two different configurations. The 12v and electric brake wires are switched. This doesn't sound like your problem so most likely it's a bad ground since you say nothing works.
Old Oct 20, 2009 | 12:42 AM
Spooler's Avatar
Yeap, I had this happen before. I would check the wiring on the trailer or just install a 7way round and dump the adaptor also. Don't rewire the truck, just the trailer.
Old Oct 20, 2009 | 12:51 AM
annabelle's Avatar
Gound was my problem when I did it.
Dean Snow
May 12, 2009 10:42 PM
durasmack
Aug 8, 2008 04:25 PM
04ctd
Feb 8, 2007 10:19 AM
zack_76401
Mar 4, 2005 11:37 AM
andyr354
Dec 17, 2004 01:48 PM
