Best stix for a Juice, 4", and HX35??
Old Apr 2, 2007 | 07:45 PM
sluggo42's Avatar
What are the best stix for this turbo? I don't want to push the envelope too much and blow smoke at all times... But I do want the max horsepower the turbo will safely handle without the EGT's going through the roof,
thanks
Old Apr 2, 2007 | 07:48 PM
Munchies's Avatar
if you want some towability. DD3's
Old Apr 2, 2007 | 07:52 PM
MSquare's Avatar
Contact Lenny or Ross at www.dynomitediesel.com and they will give you all the info you could want!
Old Apr 2, 2007 | 10:29 PM
BCSCUMMINS's Avatar
I would say a set of RV275’s unless you are going to do something with that stock auto. I don’t think it will last long with a set of 100hp sticks.
Old Apr 3, 2007 | 12:06 AM
Big Blue24's Avatar
I run RV's. Good Power, Pretty good EGT's too. I'm not afraid to tow anything. But 100 HP sticks is probably all that a stock HX 35 can handle with a Juice. I can now hit 1400* from a dead stop to 90 MPH with Juice on 5x5. That's 70* weather and 5000 feet elevation, and about 33-34 psi boost in my 5 spd, I would let her run up to 35-36 psi but 33 psi is about all she can make empty on the street. I was thinking about some Jammer 3's but I'm pretty sure I couldn't run them in a 1/4 mile, the Juice would definately go into EGT backdown. Maybe some Mach or DDP 100 HP injectors will run a little cooler than the dirtier edge nozzles but I digress.
Old Apr 3, 2007 | 05:04 AM
TorqueJunkie's Avatar
I love my DD3s, but then again I don't have a stock auto to worry about hurting either...
Old Apr 3, 2007 | 06:21 PM
Big Blue24's Avatar
Can you tow with DD3's?
Old Apr 3, 2007 | 09:07 PM
Munchies's Avatar
i can keep my foot to the floor in 3rd with dd3's and a catcher ecm with the tst turned off, towing the gooseneck with cabover and jeep on it and continue to gain speed
OldSmokey
18
Dec 16, 2007 10:30 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Don M
16
Nov 10, 2006 10:11 AM
CSAGrey1
Nov 1, 2006 10:58 AM
