BD Twins
Old May 29, 2007 | 07:12 PM
bridleman's Avatar
BD Twins
Just curious if anyone has run the BD twins and what they think of them. Good for towing, low egts , and HP any imput would be great.
Old May 29, 2007 | 11:13 PM
WildBill's Avatar
Mine's a 12V, but I love my BD twins. I like to have the power and still be able to use it. I'm sitting 425hp or so with a 5 speed. I haven't towed a whole lot of weight since I upgraded from the Super B single, but I gained hp & torque by burning more of the fuel I've been throwing at it, and lowered my exhaust temps at least 300 degrees. Before, with the truck empty, I could easily go over 1300 degrees. Now, towing 7500-8000 pounds, I didn't get to 1100.Good thing you've got head studs already. I went from 43 psi to 55 psi, and added studs right away! Mine pulls harder all the way through the rpm range than before. I haven't checked my fuel mileage, but seems no worse than before. Will have to put more miles on to find out for sure. On a 24 valve, they will cool higher hp than on a 12 valve, so the power levels they show would be very driveable and usable on your truck.
Old May 30, 2007 | 08:02 AM
Dshiftff's Avatar
I ran 618/1233 on saturday with mine on Dunbars rollers. They didnt come close to cleaning up the smoke but on the short dyno run they managed about 1300° with water/meth running. I would say they are good on a 12 valve to possibly the 550hp range before you outgrow them. FWIW, i am running 65 lbs boost with them and the responsiveness is similar to stock
Old May 30, 2007 | 11:59 AM
RowJ's Avatar
Love my BD Twins. Great kit. Excellent for towing and good up to 600 hp...with the right set up. Spool up is as fast as a Stock HX-35 and EGT's are much easier to control than with a big single!
RJ
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
stlsparky
Nov 21, 2005 10:02 PM
