battery blanket
Old Jan 15, 2005 | 12:59 AM
LanceD's Avatar
battery blanket
does anyone know if battery blankets work? at what temp would you need them, and how much warmer do they keep the batteries? also where can you buy some at?
Old Jan 15, 2005 | 08:12 AM
infidel's Avatar
Buy one here http://www.jcwhitney.com/autoparts/P...X/appId-480220
or you can buy one from Cummins for ten times more money.
Good batteries have only 75% of their cranking power available at 10°F . By -5°F , only about 60% is available; by -40°F, cranking power is virtually non-existent.
Remember when you plug in that the underhood temp will very rarely drop below even freezing. I once took a infrared temp gun around my truck on 0°F day, no wind, after being plugged in for 12 hours the top of the engine was over 80°, the radiator over 100°, the top inside of the hood in the 30°s, the bottom of the oil pan in the 40°s and the steering wheel in the 20°s. Didn't measure the batteries but bet they were probably at least in the 20°s. Couldn't get exact numbers, once the hood was open the temps started dropping really fast.
I get by without battery heaters in Montana, highly doubt you'd need them in DE.
Old Jan 15, 2005 | 11:33 AM
msing's Avatar
A warm battery will charge faster and have more cranking amps I think it shoud help with the life of the battery. My diesel VW came with one as a delier install still has org. battery 10 years old and 320k later.
Old Jan 15, 2005 | 09:41 PM
durasmack's Avatar
10 years on a battery is incredible...... battery companies would go out of business doing that..... no repeat customers?!?!
Old Jan 15, 2005 | 10:36 PM
Eat Beef's Avatar
From: Alberta Foothills - Power to grow with 6 in a row - XLR8
Battery blankets boil the batteries. Wouldn't advise using them.
Andy
Old Jan 16, 2005 | 02:18 AM
1st gen Hobie's Avatar
I rember my auto teacher say that a teacher with a bad battery just took it inside with him at school. Just put it back in before leaving. Always warm. Might be too much work for our big ones though.
Tallguy67
Nov 19, 2010 02:02 PM
Bad Ramer Jamer
Nov 28, 2005 02:56 PM
v12xke
Dec 3, 2004 03:13 PM
TinJim
Apr 9, 2003 07:00 PM
rshelton88
Jan 10, 2003 08:12 PM
