Balancing & Calibrating a P-Pump
Old May 13, 2006 | 02:00 PM
Bobcat698's Avatar
Looking to have my pump balanced and calibrated.. Is this worthwhile on a 180 pump?
I have already performed some of the AFC & rack travel modifications, but I'm looking for MORE fuel.
Lets hear some opinions please.
Old May 13, 2006 | 06:23 PM
ratsun's Avatar
From what I understand you would be better off to spend your money on a 215 pump or change the cam in yours as it dosent take much reach the max of the 180s cam. The DVs you have will give you allot more with a different cam (fill time profile)
Old May 13, 2006 | 07:04 PM
RonA's Avatar
I just had an 887 worked on at Industrial Injection is Salt Lake City. They increased the output a bit and balanced it. It is the best running pump I have had. Took about a week and was around 200 dollars for what they did. Smooth running and springs were adjusted perfectly. Top notch job! I don't mean for it to sound like an advertisement, but they did a nice job. (not everyone does.)
Old May 14, 2006 | 07:18 AM
zstroken's Avatar
Muted User
Pump
Did they turn up the fuel, or just check the flow??
Old May 14, 2006 | 08:58 AM
RonA's Avatar
They turned it up a bit. Just enough to get back up to the 500hp mark. There's about 20% more available without changing plungers and barrels.
Old May 14, 2006 | 10:35 AM
hotmopr's Avatar
How do they do that?
Old May 14, 2006 | 10:56 AM
RonA's Avatar
I do not know what is done. I have heard that it involves changing the amount of rack travel. It is alot cheaper than buying injectors.
Old May 14, 2006 | 12:30 PM
bgilbert's Avatar
It was magic..
Old May 15, 2006 | 12:30 AM
12valve's Avatar
i have no proof for this,,, but a guy told me, taking out the big plug on front of the pump, and there is the thing that moves with the governor... he said grind that down a bit, so it will travel further forward... can only be done with the pump off.... i looked in that plug, but havent done anything to it.. what do you think?
Old May 15, 2006 | 08:03 AM
RonA's Avatar
Originally Posted by bgilbert
It was magic..
No. Magic is what it takes to make a VE pump hold up once it's been bumped up to modest p7100 output.
Old May 15, 2006 | 09:53 AM
12valve's Avatar
DOES A vp PUMP die even easier when modded, or with a box or two?
Old May 15, 2006 | 10:04 AM
RonA's Avatar
I have heard they die a bit quicker with mods. I never ran mine with the VP-44. It was converted before it was bolted in place.
My "magic" comment was directed at the rotary pump in Bills truck.
DieSeLCtD
Sep 5, 2007 07:09 PM
JPR Ram
Jun 30, 2007 04:16 PM
wreedCTD
28
May 15, 2007 04:55 PM
Brock
Jun 22, 2006 04:41 PM
belfert
Feb 13, 2004 01:01 AM
