B1 is Installed and Running!!!
Old May 12, 2005 | 01:22 PM
  #31
RowJ's Avatar
Originally posted by 4doogie
TAG? havent heard that one before. Care to fill me in?
http://www.dieselpowerproducts.com/tag
Old May 12, 2005 | 01:49 PM
  #32
Saxet Nomad's Avatar
Originally posted by rjohnson
.... in my case. I used a micrometer on a KSB1-2 and my KSB-1. Both exhaust (turbine) housings had same I.D. and both turbine blades measured 2.500" dia. .
I'm trying to figure out how to measure the housing on my HT3B. Vendor was wanting to know to give me a price on a twin setup. Can anyone elaborate on how to measure...????
Thanks,
Old May 12, 2005 | 02:40 PM
  #33
RowJ's Avatar
You need internal cm2...as you probable know! That takes internal measurements and a lot more Calculus than this poor CTD driver knows. Sorry!
With just the radius on the turbine housing...along with the model #, Holsett, or a dealer ought to be able to come up with something close...maybe?
RJ
Old May 12, 2005 | 05:28 PM
  #34
Actually he was asking if it was a 26mm or not. I bought it as a 26mm, but just wanted to make sure. Did not know exactly where I needed to measure the thing. Thanks
Old May 12, 2005 | 09:37 PM
  #35
signature600's Avatar
Towed with the lag pig tonight...about 125 miles, only 20 of them interstate.
Verdict...Spool-up isn't bad if you get on the throttle, as long as you don't mind the smoke . It's not really bad, ust hard to get used to not having instant boost. It's better on the freeway, but still too laggy for me. Just takes forever to get this thing up on boost with my meager fueling.
I'll get used to it, I'm gonna check mileage on my first tankful tomorrow,
Chris
BTW, judging by the numbers I posted above (44psi@1400*@110mph), what kind of power do you think I'm at??? I never thought I'd gain boost going to a bigger turbo, and I really can't believe I've got that much fuel . Thanks Guys
Old May 12, 2005 | 10:34 PM
  #36
Cummins4Life's Avatar
Throw some bigger delivery valves and 370's in there and she'll spool.
Check my sig for common bombs and power numbers.
Old May 12, 2005 | 10:57 PM
  #37
Originally posted by Cummins4Life
Throw some bigger delivery valves...
Maybe
... and 370's in there and she'll spool.
NOT A CHANCE!!!
Thanks for the suggestions, though
Chris
Old May 13, 2005 | 03:04 PM
  #38
Cowhand's Avatar
Re: Re: B1 is Installed and Running!!!
Chris, B-1 recommends a break in, at least they did to me...basically, go easy for first 400-500 miles. I seem to remember something about keeping it under 20 psi for 1st 400 miles and under 30 psi up to 1,000 miles. Can't exactly remember...but it makes sense when you think of those suckers spinning at 100,000+ rpm.
Hope you enjoy it! B-1 or HX-40 downpipe?
RJ
Ken Diaz told me no break in necessary.....run it!
Old May 13, 2005 | 05:00 PM
  #39
Re: Re: Re: B1 is Installed and Running!!!
Sweet!!!
Chris
jaconst
Aug 16, 2014 11:00 AM
black&blue
Feb 18, 2009 08:32 PM
mullishacrew
Apr 27, 2008 04:54 PM
MoparRiggan
29
Dec 5, 2005 05:52 AM
deere nut
Jun 9, 2004 02:04 PM
