B1 is Installed and Running!!!
Old May 9, 2005 | 08:48 AM
signature600's Avatar
Got me a new turbo FINALLY!!
Full-On B1 with wastegate...install was almost easy except there's not much clearance for the Compressor outlet, drain tube, and wastegate actuator on the bottom side...but we got it.
Initial results are spool up is "delayed!" Lights about 20psi at 1800RPM, but makes a smokey 10psi at 1500RPM. Just something I'll get used to. I made it almost 30 miles befor I flipped off the Valet and poured the coal to it.
It was dark, so I couldn't tell if the smoke cleared up or not, but that's the first time I've ever had my truck to 110MPH. EGT's were 1400* @ 44psi...I need to check the wastegate and see if and when it's opening. Either way that's alot better than 1600*+ @ 42psi and 95MPH.
Now I need to hook up the trailer and see how it acts while towing, hopefully just as good as empty.
Chris
Old May 9, 2005 | 08:53 AM
Beast2B's Avatar
congrats! a little lag sure adds to the punch once it kicks in, huh?
ALL
Old May 9, 2005 | 10:30 AM
duke1n's Avatar
What turbo did you replace?
Old May 9, 2005 | 02:52 PM
RowJ's Avatar
Re: B1 is Installed and Running!!!
Chris
Chris, B-1 recommends a break in, at least they did to me...basically, go easy for first 400-500 miles. I seem to remember something about keeping it under 20 psi for 1st 400 miles and under 30 psi up to 1,000 miles. Can't exactly remember...but it makes sense when you think of those suckers spinning at 100,000+ rpm.
Hope you enjoy it! B-1 or HX-40 downpipe?
RJ
Old May 9, 2005 | 04:07 PM
rharveysr's Avatar
Things must have changed on the break in since I did my last one. Back when the only person that you could get them from was Kurt Yardley(KwikKurt) it was a much shorter break in. I ask him how much of a break in period did I need to tell the customer..he said to start the truck,check for leaks,warm the truck to operating temp...and then do a smokey burnout in front of the house... Maybe the burnout was the break in period!
Rick
Old May 9, 2005 | 04:19 PM
RowJ's Avatar
Consider the source...same guy who sold me a downpipe that would not fit my B-1 turbo. Cost me a lot more than should have to get it fabricated to fit!
I don't know if turbos, in general, require any breakin or not...just repeating what I was told.
RJ
Old May 9, 2005 | 04:34 PM
rharveysr's Avatar
I agree with you...I do what the company tells me to do...more or less
Rick
Like I said, I tried, but I couldn't resist!
HX40 downpipe...what's different with the B1 downpipe!
I replaced the stocker.
I'm gonna take it for a good drive tonight after I check everything over again, I'll keep you guys informed.
Chris
Old May 9, 2005 | 05:19 PM
Cummins4Life's Avatar
You get 1400* EGT's with just a 10plate and 300's?
A good friend of mine just ordered one for his 96 215 5spd with 100plate, 370's, and soon to have cutDV's...I hope the full B1 moves enough air.
Old May 9, 2005 | 05:22 PM
duke1n's Avatar
Who are you guys buying full B1s from. I was going to sell my B1-2 and buy a full B1 but sounds like they have back ordered on housings for the last 3 months. I remember waiting a couple months to get my B1-2. I guess I'll just send mine back and have him put the big wheel on it. I think I am going to have him JetHot coat the housings. Looks pretty slick and should hold some of the heat in the exhaust side.
Old May 9, 2005 | 05:33 PM
Mine came from Olee Poole...he had it sitting on the shelf for a customer who's engine build-up won't be finished for a while yet, so he helped me out!
Yeah, the EGT's seem kinda high for my mod's and air combination, don't they. Some people say the 300's make just as much heat as the 370's, and less power, so?!?!?
Chris
Old May 9, 2005 | 06:10 PM
Forrest Nearing's Avatar
turbo "break-in" is a rain dance... my turbo builder says "let her rip", and that's what I do...
my "fragile" HX40 has been wailed on since day one... I sneeze it quite often just to hear it chirp out the stacks still tight as the day I installed it.
big turbos are fun when they finally sign on!
Forrest
Old May 9, 2005 | 08:27 PM
TxDiesel007's Avatar
Is this a FULL on B1?
or the htt one? what is the difference? what are they capable of.. My BOMB BUCKET fund is debating H2BT or Full on B1, which is better? and congrats on ur install..
Tx
Old May 9, 2005 | 09:10 PM
Full B1 from Turbo Auto Diesel...you can tell because it has no markings whatsoever except theirs Kind cool lokking that way, if I might add
I don't know the exact differences, but this thing should handle 500hp no problems, maybe a bit toasty, but still no problem. Anymore expert opinions, I have all of 125miles on this thing now.
Chris
Old May 10, 2005 | 12:18 AM
4doogie's Avatar
im planning on 450 HP along with a KSB-1 hows that sound to you guys? will it run hot? I dont want twins, cause i dont wana go over my 10 grand bombing budget. i will have a ats manifold, and 4 inch exhuast and a scotty II. I dont wana run it hot. let me know what you guys think.
