B1-b2 Twins
Old Jan 9, 2007 | 06:42 PM
lewis369's Avatar
B1-b2 Twins
Does anyone know what kind of power a B1-B2 setup can handle or how reliable the setup is. I mean will they handle up to 600 or will something bigger be needed.
Old Jan 9, 2007 | 08:04 PM
TxDiesel007's Avatar
IIRC
Olie poole, from powerbypoole.com has a couple of trucks with that setup that did turn over 600 with the right injectors and boxes.. I know for sure an SPS62/14 over an S400 will be over 600 with the right setup, heck even a set as small as the BD twins will do it, Look at RJohnsons ride, 632 on BD's! cant beat that with a stick
Rick
Old Jan 9, 2007 | 08:17 PM
paulb's Avatar
I have an 62/14 over a S400 (basically a b1/b2), with over 30,000 miles and over 600 1/4 mile passes, without any problems at all. Very durable/reliable setup. I am over 600hp, and there is air to spare. It's a hard combo to beat. Lots of people on here are running them.
Paul
Old Jan 9, 2007 | 08:20 PM
dieselfan's Avatar
here you go this is offshoreracer sig
2002 3500 Dually 4X4 Quad Cab / Auto 4.10 / B1 - B2 Twins / O-Ring - EE Cam/ F1 Springs /14 MM Studs / Fass / DTT Full Billet with 1480 Output Shaft / Smarty/ TST Comp. Version / TST HR VP-44 / Mach 6 Inj. / NX 2 Stage N2O.............
Fall Brawl 05 656HP...............Fall Brawl 06 791.52 HP
Old Jan 9, 2007 | 08:21 PM
John DiMartino's Avatar
My buddys 01 is putting down 617 with a QS B1 on top and a b2 on the bottom,spool up with a DD cam is as good or better than a stock hx35.It spools 3x faster than my hx40/ht3b PDR setup.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
stlsparky
Nov 21, 2005 10:02 PM
