Aux Cooler Line Replacement
Old Apr 16, 2008 | 02:46 PM
james1822's Avatar
Unhappy Aux Cooler Line Replacement?
My aux cooler lines are leaking at the quick-connect fittings underneath the truck. I believe the fittings also act as a check valve as well. The dealer says it will cost $600 to replace the hoses. $100 per hose (2), plus labor. Has anyone done this themselves with aftermarket parts? Also, is the check valve really needed? I'm pretty handy but, don't want to cut the quick-connects out if their required.
Thanks!
Old Apr 17, 2008 | 09:02 AM
blackimpala's Avatar
I did a search on this, mine were leaking from a clamp that had rubbed a hole in the tubing,Seems that many have gone to all hose and eliminated the tubing. Temp. fixed mine but will do the hose thing later. Do a search for transmission cooler lines.
MAC702
Mar 2, 2012 10:56 AM
isb07
Nov 18, 2009 05:12 PM
james1822
Apr 16, 2008 06:28 PM
Crimedog
Feb 1, 2004 05:31 PM
bigredbrick
Sep 24, 2003 11:46 PM
