automatic to manual hub conversion
Old May 30, 2007 | 04:41 PM
greasy's Avatar
What do I need to do in order to instal manual (warn or other aftermarket) hubs on my Dodge 95 auto in sig?
My front drive train needs gone thru, the U joints from diff to tranny are bad and flopping around. My carrier bearing is also bad and making noise. I need to repack my wheel bearings on the front too.
was thinking might as well install locking hubs while I was at it. Someone was telling me that in order for the front drive train to 'freewheel' and not rotate while going down the road I would need to install a different gear in my diff.
I didn't see anything on search
Old May 30, 2007 | 04:51 PM
patdaly's Avatar
Do a search here, use EMS offroad or Dynatrac for the keyword.
Both make a good product, EMS is cheaper IIRC.
Old May 30, 2007 | 05:24 PM
greasy's Avatar
Thanks for the reply
found everthing I needed to know
Found out with my est. mileage per year and est fuel cost with the savings in fuel these hubs provide I would save approx $115.00 bucks per year.
So I'm looking at a good 10 years to pay these things off.
That is of course my factory hubs/bearings and such last that long then I could deduct the cost of replacing that off the purchase price of MS kit.
dang didn't know they were so much!
Old May 30, 2007 | 05:41 PM
stuckey200224's Avatar
its worth it just to be able to service the bearings and know whats going on in there and not having to worry about it
Old May 31, 2007 | 07:36 AM
patdaly's Avatar
LOL, What really does make sense as far as a payback on our trucks?
I want to change mine just so I have a PROPER front axle assy. You may also want to look into changing the entire front axle from a 90's Furd F350, in the end, it might be cheaper.
Old May 31, 2007 | 11:40 AM
greasy's Avatar
I wouldn't mind finding out more details about an F350 front end
as for the hub conversion I was just saying it's not purly finacially motovated. The improvement in ride quality and functionality is worth it. I'll be keeping this truck for a long time so I'm going to do it. I did have some sticker shock though!
I don't drive it all that often, but I'll be doing some long road trips (vacationing) so it would sure be nice.
I would love to turn it into a dumping flatbed with built in underbed tool boxes. I want it modular so the sides fold down for snowmobile/atv hauling and fold up for landscaping duty etc.
Old May 31, 2007 | 11:47 AM
dodgezilla04's Avatar
once my junky factory unit bearings go, i am going to convert to the dynatrac kit. at $550 a bearing, times both sides, the kit is only a little more than that for a serviceable unit.
Old May 31, 2007 | 12:39 PM
LanceD's Avatar
I swapped a 95 Ford F350 front axle into mine, works great and I love it. plus I sold my old 60 to a 1/2 ton guy for 800 bones
Old May 31, 2007 | 01:20 PM
frmll300's Avatar
What does it take to put the furd front end in .
Old Jun 1, 2007 | 06:19 AM
LanceD's Avatar
new brake lines, some coil/4 link brackets off a 94 up dodge ram, can be 1/2 ton. I found a bent dana 44 on ebay for 40 bucks and bought it. gave the guy an extra 10 bucks to hack the tubes around the brackets so I didn't have to ship the whole axle. heres some pics of my conversion
http://www.cardomain.com/ride/414017/9
Old Jun 1, 2007 | 12:28 PM
greasy's Avatar
nice job on that conversion
It might be a bit more than I want to chew on though. I'll keep an eye out for an axle.
how much total did you have invested into that conversion? if you don't mind
Old Jun 1, 2007 | 08:16 PM
LanceD's Avatar
about 100 bucks for the brake lines. and 40 bucks for the old dana 44 brackets. when I bought the axle I put new ball joints in it, about 120 bucks for all of them I think. thats about it. bought the new axle for 800 off of www.car-part.com and sold the old one to a guy that was putting bigger axles in his 1/2 ton
most of it was grinding and shaping the brackets to fit on the axle. measuring and lining everything up the exact same as it is on my old axle.
Rafter B
Jan 11, 2009 08:40 PM
DiEseLjunKy
32
Dec 27, 2007 07:37 AM
dieselrob
13
Jul 24, 2006 03:35 PM
HOHN
13
Feb 22, 2006 03:37 PM
rigidrotor_rt
Jul 2, 2003 08:30 AM
