Any tools needed for cam
Old Aug 5, 2008 | 05:38 AM
CoolumConst's Avatar
Any special tools needed to replace a cam on a 12 valve. Also I asume they are the same as a CR.
Old Aug 5, 2008 | 08:52 AM
98.5Hotrod's Avatar
I just replaced my cam, no special tools needed other than a press to get the cam gear on and off.
Old Aug 5, 2008 | 09:12 AM
BC847's Avatar
1st Generation Admin
You might consider a long bolt that can be screwed into the cam temporarily that can be used as a handle to help work the cam into the block.
Old Aug 5, 2008 | 09:53 AM
ratsun's Avatar
12 1/2" wood dowels 12-14" long to hold up the lifters
Bunch of elastic bands to bound the dowels together in pairs
Piece of 2" ( IIRC) pipe cut in half to slide the lifters out if your changing them.
Just your reg shop tools for the rest.
Old Aug 5, 2008 | 12:57 PM
98.5Hotrod's Avatar
Also the wood dowels for cyl 5 and 6 I cut shorter then the rest. Made them 1/2" longer then the push rods. Taped cyl 5 and 6 dowels in with the flat side of a wrench.
Old Aug 5, 2008 | 01:31 PM
Mike D's Avatar
You're need a seal proctector for the crankshaft.
Old Aug 6, 2008 | 02:04 AM
Tate's Avatar
May as well just replace the seal while you're there.
Old Aug 6, 2008 | 12:57 PM
XLR8R's Avatar
I have an old ratchet handle I TIG'd to a long bolt w/12mm thread... makes that rear journal insertion a lot easier!
etn550
Apr 1, 2010 12:12 PM
sallyman1
Feb 8, 2009 09:05 PM
AH64ID
Jan 18, 2009 04:59 PM
Pigpen
May 17, 2004 08:35 AM
fboese
0
Dec 10, 2002 04:01 PM
