Another lift pump dead
Old Mar 17, 2005 | 08:56 PM
airman's Avatar
Angry Another lift pump dead
Well here we go again,I know I'm not that hard on my truck.I drive it to work everyday but I take care of it.Two Blue Holleys Two Carters and I can say that the Holleys out last the Carter pumps and they are rated for diesel fuel.The last carter I put on the week of Christmass did not last long at all Just started falling off on the preasures.It seems to happen when it is cold weather I think they just can not handle the thicker fuel when it gets cold.Anyway I ordered a Fass this morning should be here by Monday.Man I hope it last if not a may just have to set fire to it.
Old Mar 17, 2005 | 09:13 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I've either had terrific luck or it's the Fuel additives 'cuz Pump 1 died @ 37,000 and pump 2 is still pumpin' at 75,000.
Old Mar 17, 2005 | 10:52 PM
TEXASTURBO's Avatar
I hear that. My fourth stocker died friday tried one Holley it lasted about 90days.
I couldnt find a Fass anywhere . Seems there on backorder until April.
I ordered a Barry Grant Billet internal bypass pump this morning .Hope it works for awhile. I getting sick of the hassle.
Old Mar 18, 2005 | 09:19 AM
firestorm's Avatar
I don't run additives, other than 5 gal. of kerosene every 20k. My first one was at 37,000, and at 102k this one is weak ( 12,10,4). I have a new Lift pump and am installing a pusher.
Old Mar 21, 2005 | 02:41 PM
airman's Avatar
Well I am going to give a update on my lift pump,I ordered a Fass pump from RBR on Thursday and it came in the next day which realy surprised me.And just my luck when I pulled the plugs out to install the fuel lines a spring fell out so I called Steve at RBR and I would recomend RBR to any one realy nice guy to do buisness with he called me back after hours and told me to call him anytime that he understood,anyway I took the pump apart and found that the spring had not been installed properly.I put it back together and it is working fine now.It seems that Diesel Performance products has some quality isues.also they put a waranty parper in the box to send in with no address to send it too,thank goodness for the enternet.If anyone needs a fass pump he has them in stock there number is 1-800-805-5487 ask for Steve.Great service on his part.
Old Mar 21, 2005 | 03:24 PM
Turbo Deeezle's Avatar
I hear ya there.......... 127,000+ on original pumps. I throw in some additive when I remember to. I'm a lucky dog !
Old Mar 21, 2005 | 03:26 PM
Moose10's Avatar
Not to change the subject, but what is the purpose of 5gal. of kerosene every 20k. Cleaning?
Old Mar 22, 2005 | 08:56 AM
firestorm's Avatar
Yes. The station I fill up at also has kerosene. I put 5 gal. kerosene to maintain the injectors and the rest of the fuel system, then top the tank off with diesel.
I installed the pusher with the weak pump still there. Now my PSI's are 18 13 8. The lift pump is going in this week end.
Old Mar 22, 2005 | 05:03 PM
mini14's Avatar
u should be using additives not kerosene. it has lowers btu's, and is more expensive then a bottle of additive. kerosene is blended with no. 2 to prevent gelling in the winter. u live in florida not a concern for u.most northerners will get 1-3 mpg less in the winter due to the kerosene and frigid temps.
Old Mar 22, 2005 | 05:19 PM
tool's Avatar
Also, the Kerosene you are putting in there may be "marked" or "dyed" and is not intended to be burnt in vehicles. You pay no road tax on it so it is therefore illegal to burn in your truck.
(I realise you are only using a small quantity periodically but you can still get in trouble)
vikingsven
Oct 29, 2006 08:28 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
billygoat02
Dec 30, 2005 09:19 AM
wrk24wheel
May 1, 2005 07:18 PM
