Another Comp Question
Old Jan 30, 2007 | 05:17 PM
GoldGoat's Avatar
The other day I noticed that the gray wire that you tap to the bump Is not hooked up to the back of the comp box Is every body elses that way or have I unhooked it some how.
Old Jan 30, 2007 | 06:21 PM
NotMatt's Avatar
So the pump wire is tapped, but the wire leads to nowhere? Yeah, to get the most amount of power from the truck, you need to have the pump wire hooked up... otherwise it can only make minor adjustments in performance.
Old Jan 30, 2007 | 06:52 PM
GoldGoat's Avatar
Well I cant tell if I knocked the wire loose or if it can from edge that way. The truck still runs good and you can tell a significant difference between the levels. I guess I can solder it in and see what happens.
taken5875
Apr 4, 2008 12:48 AM
Jezzhuntin
Aug 25, 2006 02:51 PM
I SPEED
Sep 11, 2005 08:20 PM
duallydave
May 18, 2005 10:06 PM
rockjeep73
Mar 25, 2005 03:34 AM
